Author Topic: 1962 F100 unibody drag truck  (Read 95385 times)
Re: 1962 F100 drag truck
« Reply #60 on: March 29, 2019, 10:35:14 AM »
I like the speed holes in the front core support.
We started with the same trans brake button placement on the 64 fairlane drag car. The cord would wind around the steering column and after about a half season the cord didn't cooperate anymore. After that we got a handheld switch that you could set down after launch, wasn't as great as it looked in theory. Ended up with a normal momentary switch that was placed on the shifter housing, it was a B&M shifter with the aluminum cover, just riveted a little switch plate to the side of it. That's how the car stayed for 8 years until it was retired.
KMcCullah
« Reply #61 on: April 01, 2019, 02:31:29 PM »
I like the idea of having both hands on the wheel when coming out of the hole, so that's how the transbrake button wound up on the steering wheel. But like you said, the cord doesn't want to wrap around the steering column very well. I messed with it some yesterday. Tried wrapping some masking tape around the steering column to help the cord slide instead of stick. Didn't work very well. It's a work in progress for now. I have to learn to drive all over again with this rig.
« Last Edit: April 01, 2019, 06:23:42 PM by KMcCullah »
Kevin McCullah
Leny Mason
« Reply #62 on: April 04, 2019, 10:47:09 PM »
Why cant you use the horn button wire to run the tranny brake just a thought. Leny Mason
KMcCullah
« Reply #63 on: April 06, 2019, 10:08:40 PM »
Hey Leny, we considered the horn wire. But the old eight pin connector in the firewall had a broken pin to the tail lights. So the pin for the horn wire was sacrificed for the tail lights.
Kevin McCullah
KMcCullah
« Reply #64 on: April 06, 2019, 10:42:59 PM »
We finished up with the wiring and mounting the battery last weekend. The master kill switch we used had a second pole in it that was used to power the fuel pump.
The fuel system didn't take us too long. The fuel cell is a Speedmaster unit. Decent quality for the price. We started out using the Trick Flow 140 fuel pump that was in my Highboy with the 504. Then ran 1/2 soft copper tubing to the pressure regulator and cool can on the firewall. Will see if it passes tech. I cant say I've ever seen soft copper used for fuel line at the track. But it worked on the Model T.  ;D
After getting the CVR starter mounted, we dumped a few gallons of gas in and cranked it up. Man it was good to hear that 504 idling again. Heck it was mothballed for a couple of years. I'll have to get some video to post. But no major issues to report. The C6 clicked thru all the gears. No oil leaks. The alternator is charging at 14.4 volts. The CVR water pump cools really well. But our cacklefest was cut short due to a blown seal in the Trick Flow pump. Sitting around for a few years dried it out I guess. No biggie. It was incredibly loud anyhow. We had another Holley knock off pump kicking around.
We're moving on to the roll cage and seats now. That will be a couple of weekends to finish.
We're trying our best to make the test and tune at our local track. It's on 4/27.....
« Last Edit: March 14, 2020, 11:17:24 AM by KMcCullah »
Kevin McCullah
Joey120373
« Reply #65 on: April 07, 2019, 12:00:26 AM »
Kevin, Man that truck is looking good. Ill have to check my work schedule, I may drop by the test and tune if you make it.
Is there a grommet for the copper fuel line where it pokes through the bed? Cant make it out in the photos, if not the tech inspector might not like that.
« Reply #66 on: April 07, 2019, 06:43:47 AM »
Great looking engine, Kevin, looking forward to hearing about the track results!
« Reply #67 on: April 07, 2019, 10:39:38 AM »
Yes, a great looking engine! Like the as-cast look a lot.
Headers with that straight-out 1st tube section looks good for hp production. Missed if you welded them up or bought them.
KMcCullah
« Reply #68 on: April 15, 2019, 02:29:30 PM »
Thanks for the kind words guys.
https://m.youtube.com/watch?v=Fo66ODKSDdQ
Kevin McCullah
« Reply #69 on: April 15, 2019, 02:38:43 PM »
Sounds great! We were sitting in the garage Friday night kicking around the idea of heading over the hill sometime this summer and racing in Grand Junction. That's your track right?
Car just got repainted. Factory colors, just a refresh.
KMcCullah
« Reply #70 on: April 15, 2019, 09:53:24 PM »
Hey that Fairlane looks cool! I like the color too.
Yep GJ is me. They just posted the 2019 schedule.
http://wcdra.com/race_schedule.htm
 We hit a few of the Friday night street legal drags last year. Thrashed on dads 1971 F100. We may try the Quick 16 guys if thing work out well with the package.
Holler if you come over. PM
Kevin McCullah
« Reply #71 on: April 16, 2019, 12:14:26 AM »
The truck looks awesome, Kevin! Only thing missing is the 4 speed.  :)
I noticed in the video, the oil pressure gauge seemed a lil "lazy". That would drive me nuts.
« Reply #72 on: April 16, 2019, 05:59:32 AM »
I was thinking the same thing nightmist, wasnt going to say anything figuring just a lazy gauge.
KMcCullah
« Reply #73 on: April 16, 2019, 07:19:15 AM »
Yea the oil pressure guage bugs me too. Dad insisted on mechanical guages. So the oil pressure takes a while to travel up the 1/16 copper tube. 15-40 Rotella with 35 deg temps compounds the lazy issue.
Kevin McCullah
« Reply #74 on: April 16, 2019, 07:49:33 AM »
That'll do it. 3 or 4 AN line would fix that. I was using a 3 AN line to my gauge, but with 10W30. Never an issue.
