Author Topic: 545" High Riser Build  (Read 285403 times)
westcoastgalaxie
Re: 545" High Riser Build
« Reply #195 on: June 11, 2012, 11:02:06 PM »
Jay, questions about the slip fit headers. Always took them to be an assemble in the car and weld everything in place. I see with yours that they are not such and are removable. I see what appears to be a bracket for mounting at the connection points. But how do they seal?
« Reply #196 on: June 12, 2012, 07:21:42 AM »
If you put some high temp silicone in the tubes when you slip them together they seal OK for a while.  Eventually, though, they will start to leak.  I think that is the price you pay for slip-fit tubes.
westcoastgalaxie
« Reply #197 on: June 13, 2012, 09:54:07 PM »
Gotcha, thanks for edjumacating a young buck
philminotti
« Reply #198 on: June 28, 2012, 12:06:07 AM »
Hey Jay.  Any news on the big 545?  Inquiring minds want to know....
« Reply #199 on: June 28, 2012, 08:57:46 AM »
Behind schedule, but finally moving again, Phil.  I'll have a detailed update after this weekend - Jay
Joe-jdc
« Reply #200 on: June 28, 2012, 09:11:52 AM »
Was just going to ask the same thing since I have been out of town for a few days.  Wondered what was going on up there.  Hope it surprises you with great numbers.  Joe-JDC.
Joe-jdc
« Reply #201 on: July 06, 2012, 10:10:11 PM »
ARE YOU walking softly and carrying a BIG STICK?  HOPE SO, want to shut up a certain mouth.  I hope you have a great week, and put the naysayers to flight.  Is there anything I can do to help for afar?  Joe-JDC.
« Reply #202 on: July 06, 2012, 11:45:46 PM »
Thanks for the offer, Joe, but I'm good.  As usual things are behind schedule here, but my short block is going together tomorrow and most of the engine will be assembled after next weekend.  My friend Scott Clark will be coming up to help with the dyno session on July 28/29.  Should be an interesting time.
Don't let the mouth on the FE Forum bother you.  He is only a keyboard racer  ;D
fetorino
  • Tunnelport Cobra
« Reply #203 on: July 07, 2012, 12:37:15 AM »
Jay  I speak for many when I say I can't wait to see your high riser dyno session.  The mouth doesn't realize the real best FE is a tunnelport :LOL
427Fastback
« Reply #204 on: July 07, 2012, 12:38:58 AM »
I dont think he is even a keyboard racer....
JMO..Cory
I have edited my post...I was really pissed off when I read Mr Gordon's post
« Last Edit: July 08, 2012, 11:04:23 PM by 427Fastback »
1936 Diamond T 212BD
1990 Grizzly pick-up
« Reply #205 on: July 08, 2012, 10:40:23 PM »
Finally got back to the high riser project this weekend, after getting the Galaxie back together (replaced the flywheel with an ATI unit).  Re-starting from scratch, I assembled the short block over the weekend.  All the clearances looked good, and things went along pretty well with one exception.  This is the first time I've assembled a short block with Dykes rings, and on the first piston I tried to go a little too fast, jammed the top ring between the tapered ring compressor and the piston, and put a bend in the top ring.  After that I was more careful, and got seven of the pistons and rod assemblies installed with no further problems.  I'll call in the order for a replacement top ring tomorrow, and hopefully will have that by the end of the week.  In the meantime, there's a lot of other things I can be doing, such as assembling the heads, finish welding up the oil pan, install the cam and Danny Bee belt drive, finish machining the oil pump and alternator brackets, etc. etc.  I'm hopeful that by next weekend the engine will be all together, save for some of the plumbing and accessories, so I'll be ready to dyno it at the end of this month.  Here's some photos of the short block and a piston/rod assembly:
I'll post another update next weekend.
« Reply #206 on: July 09, 2012, 04:22:39 PM »
Love the shot with the Cleveland 2X4 peeking around the corner.
The engine is bad ass Jay!
« Reply #207 on: July 09, 2012, 07:09:10 PM »
Yeah, I'm in the middle of the intake adapter project as well, so there's a bunch of 351C stuff scattered amongst the FE parts  ::)
« Reply #208 on: July 13, 2012, 09:53:15 PM »
The motor continues to go together...
lovehamr
« Reply #209 on: July 13, 2012, 11:19:20 PM »
Holy crap those ports are huge!  What sort of flow #s did you get out of them?
