Author Topic: Scat crankshaft  (Read 13254 times)
Re: Scat crankshaft
« Reply #15 on: March 26, 2020, 07:10:50 PM »
I have 2 cracked 428 cranks sitting here now.  I gave a third one away a couple weeks ago, to a guy who wanted it for mockup purposes.  Not saying they aren't tough, but after 50 years and some abuse, I wouldn't trust one...
FElony
Re: Scat crankshaft
« Reply #16 on: March 26, 2020, 07:58:08 PM »
The answer here is simple. If the car in question is an actual CJ Mach, then the original crank should go back into the original block and assembled with correct N heads, C intake, cast exhausts and the rest. Take all the aftermarket bits and build a cammed beater engine to stick in a different car. Simple.
FElony
Re: Scat crankshaft
« Reply #17 on: March 26, 2020, 08:01:52 PM »
... Picture of one of my Ford 428 cranks.
If I was that rusty and someone dropped me on that concrete, I'd have spinal alignment issues, also.
Re: Scat crankshaft
« Reply #18 on: March 26, 2020, 09:05:02 PM »
That crank broke when it was in the car, thatdarncat's 67 Shelby.  It's been sitting around for a while, obviously...
FElony
Re: Scat crankshaft
« Reply #19 on: March 26, 2020, 09:31:52 PM »
You're a shill for Scat, obviously. However, I won't press charges if you hurry up and sell me the red car.
Re: Scat crankshaft
« Reply #20 on: March 26, 2020, 10:20:25 PM »
You're dreamin', buddy  ;D  Got plans for that one...
FElony
Re: Scat crankshaft
« Reply #21 on: March 26, 2020, 11:44:52 PM »
Don't make me resort to my proven methods.
https://i.ebayimg.com/images/i/201305838489-0-1/s-l1000.jpg
« Last Edit: March 26, 2020, 11:47:29 PM by FElony »
Re: Scat crankshaft
« Reply #22 on: March 26, 2020, 11:58:35 PM »
Stock Ford cast FE, and 428, cranks are good, but they’re not invincible. Don’t get me wrong, I still use my Ford cranks, but like Jay said, the Scat crank is fine too. Barry has commented on the Scat counterweight - piston skirt interference before, so it’s not an unknown issue, Since you have the Scat crank I’d probably consider Barry & Brents advice and look into either an exchange or have your machine shop make the required modifications. Picture of one of my Ford 428 cranks.
I broke a 428 iu crank just like that one. It could pass for mine ..
FElony
Re: Scat crankshaft
« Reply #23 on: March 27, 2020, 12:17:56 AM »
Damn, you guys sure like spitting rods and valves out, 'cuz 1U's just don't do that by themselves.  8)
Re: Scat crankshaft
« Reply #24 on: March 27, 2020, 10:21:05 AM »
Just offhand, I can think of at least 5 forum members who have broken 428 cranks over the years. All drag racing, but that's the caveat of a used crank, you don't know what its been through.
pbf777
Re: Scat crankshaft
« Reply #25 on: March 27, 2020, 12:40:30 PM »
      From our experience over the decades of magnaflux testing of Ford O.E.M. 428 cast iron crankshafts, on what I call "first-go-a-round" (at least it's still standard bearing journal size anyway) with generally typical passenger car use, I'd say about 20% have proven to be failed (cracked)!         :o
      This being perhaps slightly better than the typical 5.0 S.B.F., but probably the next most likely to prove cracked unit of any in the Ford V8 lineup.          ;)
      Scott.
Mach1428cj
Re: Scat crankshaft
« Reply #26 on: March 27, 2020, 12:59:10 PM »
I called Scat and visit with them on my problem. They indicated to me I need to go with a different piston when using this crank as the pin boss is to large on the older stock replacement TRWs. I asked why that wasn't that stated in the description of the crank as it does say stock replacement. Didn't have an answer . He indicated that he could either throw me a deal on pistons or give me a deal on a complete rotating assembly such as a 462 stroker for my trouble. He told me he would give me a complete balanced 462 kit for 1,488.00. Is this the way to go or should I buy pistons and have everything rebalanced and go that way. Sorry for all the questions just don't know which way to go.  Is the 462 a good combination for the street also would there be any block mods to do for clearances when using a stroker
« Last Edit: March 27, 2020, 01:12:44 PM by Mach1428cj »
Re: Scat crankshaft
« Reply #27 on: March 27, 2020, 03:22:19 PM »
That is an incredible deal on the 462 - I would go that route in a heartbeat.
No special clearance or grinding needed, and extremely street friendly
Re: Scat crankshaft
« Reply #28 on: March 27, 2020, 06:08:57 PM »
^^^  This!
Gaugster
Re: Scat crankshaft
« Reply #29 on: March 27, 2020, 07:07:43 PM »
Green with envy!
