Author Topic: Scat crankshaft  (Read 13238 times)
Mach1428cj
Scat crankshaft
« on: March 26, 2020, 01:46:14 PM »
I am new to the posting on this form but have been reading the topics for quit some time. Very interesting and helpful. Thank you. I have been restoring my 69 Mustang and decided to freshen the 428 as long as the car was apart. The crank ended up being in not so great shape it already had been cut .010 and .020 so I decided to go with a Scat crank. I had the machinist repair the oil slinger on the rear of the shaft as it hit the block as indicated by some other forum members. My problem now is the crankshaft throws hit the skirt on the pistons and also there is very little clearance from the crank throw to the bottom of the piston. The pistons are older TRW L2245. What are my options. Different pistons? Unsure what to do.
FElony
Re: Scat crankshaft
« Reply #1 on: March 26, 2020, 02:20:43 PM »
Not only can you cut a stock crank to 50/50, you can whack the rod journals down to BBC diameter. Pitch that Scat and put the old one back in.
1968galaxie
Re: Scat crankshaft
« Reply #2 on: March 26, 2020, 02:29:25 PM »
Agree with FElony.
Use the original 428 crank 0.030" or more cut would be perfectly fine.
The factory cast cranks are very sturdy and you would not have any clearance issues you are having with the scat crank.
Sell the scat and use the Ford crank.
Re: Scat crankshaft
« Reply #3 on: March 26, 2020, 02:36:05 PM »
You can have the counterweights cut down.
1968galaxie
Re: Scat crankshaft
« Reply #4 on: March 26, 2020, 02:42:36 PM »
I would rather regrind the factory crank than use a scat crank that has issues.
Customer can spend his money fixing the scat crank.
I personally would sell the scat crank before spending any more money to fix it.
Anyhow, just my unprofessional opinion.
Re: Scat crankshaft
« Reply #5 on: March 26, 2020, 03:00:21 PM »
I wouldn't use an old cast crank on anything other than a stock rebuild, you are better off with the Scat crank.  I have seen too many cracked stock 428 cranks.  Any good crank shop can cut the counterweights, or a better option in my opinion is to go with some aftermarket pistons with a modern ring package.  That will free up a little power in addition to solving the interference problem.
Mach1428cj
Re: Scat crankshaft
« Reply #6 on: March 26, 2020, 03:46:26 PM »
What pistons would you recommend. The car really isn't going to be drove a lot but I would imagine when I do I will want to have a little fun with it. It is a .030 over 428 with a comp 280H cam and Edelbrock heads with a PI intake. I have owned the car since 1981 and thought I would be nice and give it an intire face lift as it used to be my only car . My problem I am not made of money and when this problem came about I felt like throwing in the towel. not really. lol I do want an engine that is dependable as I really don't want to pull the elephant back out again. Ever. That why I am looking to the professionals for options and opinions. Thanks again
AlanCasida
Re: Scat crankshaft
« Reply #7 on: March 26, 2020, 04:16:44 PM »
That deal with the oil slinger hitting the block has me nervous. I replaced my ruined OEM 428 crank with a Scat 428 crank in my 427/452 but I didn't specifically check that and it's all together and in the car. I am not sure if I would have noticed something like that or not. I did specifically check the end play and it was ok though.  I've ran it and I didn't hear anything bad going on.
1968galaxie
Re: Scat crankshaft
« Reply #8 on: March 26, 2020, 04:17:37 PM »
The factory 428 crankshaft - if properly checked - magnaflux and resized will be very capable.
I have beat the crap out of factory cast cranks - zero failures. Even offset ground factory cast cranks.
Sure if you have plenty of $ to spend (as some here do), go ahead and use the scat crank, change pistons etc.....
Good luck with your project! I am sure it will be a fantastic ride when done.
Re: Scat crankshaft
« Reply #9 on: March 26, 2020, 04:38:51 PM »
You would have known on mock up.  It locks the crank up when you try to turn it.
AlanCasida
Re: Scat crankshaft
« Reply #10 on: March 26, 2020, 04:42:06 PM »
Whew! Thanks, Brent!
Re: Scat crankshaft
« Reply #11 on: March 26, 2020, 04:43:45 PM »
Lots of options for a 428....Icon, Diamond, Racetec, SRP....
You can count on spending $750-1000 for pistons and rings.
Re: Scat crankshaft
« Reply #12 on: March 26, 2020, 04:54:56 PM »
Slinger is not a real common issue.  Appears that they cut that diameter as part of a first operation in machining as it is sometimes off center from everything else.
We have only seen a few touch off on the block out of literally hundreds installed.  Pistons and counterweights are a different deal.  We saw a run of strokers where that problem popped up, but have not done very many with stock stroke 428 cranks.  I would have to imagine that it was from that same run of parts.  They had skipped a rough OD turn and it was not easy to identify - I have a dimension here somewhere that can be quickly trimmed to on a lathe - or Scat would probably swap it out if you called them.
Re: Scat crankshaft
« Reply #13 on: March 26, 2020, 05:14:40 PM »
I've seen the slinger thing several times in the past few months.  It was bad enough that I shot my rep an email and they had to go through their stock and fix some before they were able to send them out.  I haven't seen the counterweight deal in a long time.
Re: Scat crankshaft
« Reply #14 on: March 26, 2020, 05:24:40 PM »
Stock Ford cast FE, and 428, cranks are good, but they’re not invincible. Don’t get me wrong, I still use my Ford cranks, but like Jay said, the Scat crank is fine too. Barry has commented on the Scat counterweight - piston skirt interference before, so it’s not an unknown issue, Since you have the Scat crank I’d probably consider Barry & Brents advice and look into either an exchange or have your machine shop make the required modifications. Picture of one of my Ford 428 cranks.
