Author Topic: Guess the horsepower - first of two "sneaky 461" - extra cheating included  (Read 10010 times)
I am bringing two engines down to Kentucky on November 15, going to have a couple dyno days, good reason to hang around with Brent, escape Nebraska for a working couple of days "off", along with a good midpoint for the owner. This is the first of two 461s, the second I will post in another thread. I figured I'd throw it out to see what people think.
The reason I say some cheating included is that I have dyno data for a nearly identical build, same dyno, and I will include the changes here, so you are really only guessing the difference of the parts.
Here is the first CJ that was done on the same dyno.
http://fepower.net/simplemachinesforum/index.php?topic=7690.0
Here is the engine to be dyno'd, different engine completely, but listed all the changes from the last one
461 cid 428, 10.3:1, Racetech dish pistons, 1.0/1.0/2.0 Mahle rings, .010 above deck, .041 quench (all minor changes)
Heads went from CnC ported CJ iron, to Trick Flow heads name milled off to hide them a little
Intake went from locally ported CJ iron, to Joe Craine ported -F PI intake flowing between 350-370 cfm per port
Cam went from 237/237 .634, 114 LSA on 106 to 235/237 .634, 114 LSA on 107
Carb went from 830 cfm Quick Fuel Brawler to custom built Quick Fuel 780 cfm vac sec
Connecting rods went from SCAT 6.70 to Molnar 6.70 much lighter
Windage Tray went from Ford factory CJ to Canton Screen
Oil pump went from M57HV out of the box, to Doug Garifo bluepwinted M57HV with standard spring, shimmed with his provided +10 psi shim
As you can see, many small changes from the combo this summer, the biggest being the Trick Flow heads.  No prize forthcoming, but there will be a second engine to guess, and all the glory that comes with guessing it correctly!
This one is going in a 1968.5 CJ fastback Mustang, 4 speed, 3.91s
« Last Edit: November 01, 2019, 05:58:50 AM by My427stang »
338Raptor
Re: Guess the horsepower - first of two "sneaky 461" - extra cheating included
« Reply #1 on: November 01, 2019, 08:51:46 AM »
541 hp
« Reply #2 on: November 01, 2019, 11:02:11 AM »
599.3 hp    Joe-JDC
BBFORDFAN
« Reply #3 on: November 01, 2019, 11:56:15 AM »
576hp
fryedaddy
« Reply #4 on: November 01, 2019, 01:36:17 PM »
imgoing to say 588
« Reply #5 on: November 01, 2019, 01:39:43 PM »
564 HP
559 Torque
Should be fun in that car.
10.80-11.20 quarter
6667fan
  • Every Second Counts
« Reply #6 on: November 04, 2019, 12:59:38 PM »
546 peak hp
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
Gregwill16
« Reply #7 on: November 04, 2019, 09:23:30 PM »
572 hp
mn67
« Reply #8 on: November 05, 2019, 08:44:53 AM »
530 HP
1971 Maverick Grabber
Twinibeam66
« Reply #9 on: November 05, 2019, 08:47:20 AM »
543 HP
DuckRyder
« Reply #10 on: November 09, 2019, 07:23:26 AM »
I'm gonna say 533.
Good looking engine!
Robert
« Reply #11 on: November 10, 2019, 09:39:50 AM »
As I said, ready to go with two, this one looks deceivingly stock :)
Should be fun on the dyno and even more fun in a 68.5 3.91 geared fastback Mustang!
hhiibel
« Reply #12 on: November 10, 2019, 03:18:58 PM »
535hp. 568tq
« Reply #13 on: November 15, 2019, 07:57:56 PM »
Really good day on the dyno with the TF headed motor.  Really big flat curves and big numbers for a 235 degree intake lobe and 114 LSA, 780 carb, no carb spacers, dual plane, 30 degrees of advance.  Looks like a bone stock 68.5 CJ externally
HP 568 @ 5500 (carried 560+ hp from 5250 to 6250)  Only 8 hp lower than peak at 6250 rpm
TQ 578 @ 4750 (freight train torque curve at or over 570 fl lbs from 3250 rpm t0 5000 rpm!)
As with the other, I will post the numbers in the dyno section when I get home!  This will be a very mean little resto Mustang
Another great day with Brent and the gang, hope to get back soon with another build!
« Reply #14 on: November 15, 2019, 10:47:54 PM »
Should be a strong streeter.  Just curious what the idle rpm was, and how much vacuum it was pulling at idle.  That camshaft is close to what I would pick for one of my street builds, and I wonder if it would have enough vacuum for power brakes, etc.?  Sounds like it would have been the perfect candidate for a couple of spacer tests.  The ram air should work with at least a 1/2" spacer.  Joe-JDC
