Author Topic: Putting A Little Pep In My 390's Step  (Read 86403 times)
plovett
Re: Putting A Little Pep In My 390's Step
« Reply #15 on: September 03, 2019, 06:48:34 AM »
Cool.  What are the cam spec's?
falcongeorge
« Reply #16 on: September 03, 2019, 10:16:00 AM »
The bumpstick. Solid roller. I don't want to give the specs. Lift somewhere between .6-.800", duration between 260-280. Lobe separation is 110, 106 centerline.
at .050??!! GADZOOKS! :o
I wouldn't run something that small, advertised.  ;D
 ;D 8)
« Reply #17 on: September 03, 2019, 06:28:54 PM »
Beautiful work Jared, your attention to detail really shows.  I'm sure it will all pay off with a very strong engine.  Do you plan to dyno this one?  Street and strip, or strip only?
Thanks Jay. I don't think I will dyno this one. It will be street n strip. The track is an excellent dyno....
Bolted to Floor
« Reply #18 on: September 04, 2019, 10:43:05 PM »
Nice work Jared. Thanks for posting.
« Reply #19 on: September 05, 2019, 09:01:51 PM »
Thanks John. Maybe you want to rethink the stroker route this time, and do something like this.....
« Last Edit: September 05, 2019, 09:03:23 PM by Nightmist66 »
Bolted to Floor
« Reply #20 on: September 06, 2019, 10:45:06 PM »
Haha, Jared, it’s very tempting.....I’m not the most engine savvy guy, but something tells me your unspecified solid roller and 12.5 compression would not be user friendly with my desire for power brakes!!  ;D ;D Yea, I’m one of those guys.  ::)
« Reply #21 on: September 07, 2019, 06:59:40 PM »
Aww c'mon, they make vacuum pumps... ;)
Cobrajet2
« Reply #22 on: September 11, 2019, 02:36:10 PM »
Yeah, great pictures. Thanks for sharing your build. You have great attention to detail.
Mike
TimeWarpF100
« Reply #23 on: September 11, 2019, 04:33:52 PM »
very nicely done!
« Reply #24 on: September 11, 2019, 11:46:38 PM »
Mike
Thanks Mike!
very nicely done!
Thanks TimeWarp!
Cobrajet2
« Reply #25 on: October 08, 2019, 11:21:32 AM »
Hi Jared,
Not to take away from this build, but I saw on one of your other posts you had made up some steel shim plates for your rocker stands. I may need to do the same. Was that just mild steel that you used, or something fancy? I take it you just traced out the footprint of your rocker assembly?
Thanks,
Mike
« Reply #26 on: October 08, 2019, 04:54:08 PM »
Didn't see this until today. Very nice stuff, lot of patience there.
« Reply #27 on: October 08, 2019, 06:54:43 PM »
Beautyful as a spring day 8)
gdaddy01
« Reply #28 on: October 08, 2019, 09:13:26 PM »
heo , is it cold there yet ? 90 here in Florida , would like some cooler whether
« Reply #29 on: October 08, 2019, 10:23:09 PM »
Hi Jared,
Thanks,
Mike
No problem, Mike. I didn't go fancy on those shims. I figured if the stands were aluminum, even a strong grade, then mild steel should suffice. I just went to my local store and got some 1/4" thick flat stock. I bolted the rocker stands down and took an overall measurement and cut to length. Then I measured for bolt hole locations and drilled them out. Then I marked where the head studs would interfere and marked locations to notch for valvesprings. I did trace the inside of the end stands to clearance for the head studs. Then I made sure I trued the faces and got my desired thickness.
These pics are of iteration 1 of this build(RIP)
