Author Topic: FE-older brother Y  (Read 19910 times)
DEANs427
FE-older brother Y
« on: April 09, 2019, 10:32:05 PM »
299 cubic inch
4-71 supercharger
503 hp@ 6100 rpm
450 ft/lbs@ 5000
SuperFlow WinDyn v3.2 dyno
R&R performance, Spring lake park MN
Factory ECK 292 BLOCK, .050 over, cast in 1955
Factory forged 292 hd truck crank, .020 main, .040 rods, stock stroke 3.3
Mummert forged connecting rods & push rods
Diamond blower pistons w/total seal 1.5, 1.5, 3.0 blower ring pack,
Clevite rod & main bearings, Ted Eaton special cam brg.
main bearing girdle/ scraper fabricated per Ted eaton blueprints
factory oil pump, pick-up, & truck pan
Cam& lifters by Oregon cam grinding to Ken Heard specs
Mummert aluminum cylinder heads modified to fit beehive springs & oversize ex.valves
 Harlan/sharpe 1.6 ratio roller rockers
FPP double roller timing chain
Rotating assy. balanced by Ten Eaton specialties
Factory Y block distributor converted to dura spark, curved by Faron Rhodes
Blower& drive assembly by Deans Blowers out of Washington state, old school blower
Intake manifold & crank adaptor from Y-bloke enterprizes in walla walla Australia
950 holley 3rl
1956 Ford Gasser 427FE
1966 Fairlane
1966 Bronco supercharged
Re: FE-older brother Y
« Reply #1 on: April 10, 2019, 06:20:39 AM »
Look at that torque curve, that thing is gonna come on like a freight train. Awesome!! :o. Dont know alot about those blocks at .050 is that alot for those blocks or are they thicker than an FE.
« Last Edit: April 10, 2019, 06:31:41 AM by Stangman »
« Reply #2 on: April 10, 2019, 07:50:29 AM »
I think that's a 525 HP engine if you rev it a little higher, Dean.  Great job!
« Reply #3 on: April 10, 2019, 09:39:51 PM »
As with any old block, water sitting over time can rust the liners, and it is always a good idea to sonic test any of them before going very much over standard.  Most can go +.060", but occasionally one is paper thin at +.030".  My 2018 EMC 292 block is bored +.132" after sonic testing and offset boring.  I have two 292 blocks that are +.040" and will be pushing  the maximum at +.060".  One 292 that is going to be good to .+125", so sonic testing is worth the time and money.  Joe-JDC
« Reply #4 on: April 11, 2019, 11:06:10 AM »
Thank You Joe!
DEANs427
« Reply #5 on: April 11, 2019, 05:11:19 PM »
Y block sonic test results:
1966 Fairlane
« Reply #6 on: April 11, 2019, 07:11:53 PM »
Nice thanks for the test, pretty good meat.
Royce
« Reply #7 on: April 14, 2019, 11:39:25 AM »
Dean the Blown 292 must make close to the power your 427 made..  Watch out FEs !  Y Blocks: Torque of a locomotive, RPM of a die grinder. And every one is a side oiler...
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
« Reply #8 on: April 14, 2019, 11:53:53 AM »
I'm shakin' in my boots - not  ;D  Royce, I see you are spouting the Y-block party line  ;D
« Reply #9 on: April 15, 2019, 05:52:28 AM »
Dem sounds like fightin words, maybe a 332 FE against a 292 Y bock is in order one of these days!!!???. ;) 8)
Royce
« Reply #10 on: April 15, 2019, 07:40:21 AM »
I am all in!   I have a 333 Y block itching for a fight
1992 BMW V-12 5.0
DEANs427
« Reply #11 on: April 15, 2019, 09:48:21 AM »
"Its not the size of the dog (motor) in the fight, its the size of the fight in the dog", applies here
1966 Fairlane
« Reply #12 on: April 15, 2019, 12:50:23 PM »
Can I bring my "lil" 292 to this competition?  Joe-JDC
DEANs427
« Reply #13 on: April 15, 2019, 01:55:06 PM »
As for comparing dyno numbers, Jay probably has a couple of my 427 numbers in his archives.
Don't forget to compare these numbers, thick FE 427 block $4000+, thick Y block $100, FE forged steel crank $1000, forged steel $ sign Y crank $200
This does appear to be a call-out, when I first started the Nostalgia, heads-up racing with the gasser I got called out quite often, usually by shiny chebbies, after the first couple of seasons there were not very many call-outs any more...
Joe, bring your Y out for sure !
1966 Fairlane
« Reply #14 on: April 15, 2019, 02:16:00 PM »
Great, something else to sidetrack Jay lol. He will never get those heads done
