Author Topic: FE-older brother Y  (Read 7786 times)
DEANs427
FE-older brother Y
« on: April 09, 2019, 10:32:05 PM »
299 cubic inch
4-71 supercharger
503 hp@ 6100 rpm
450 ft/lbs@ 5000
SuperFlow WinDyn v3.2 dyno
R&R performance, Spring lake park MN
Factory ECK 292 BLOCK, .050 over, cast in 1955
Factory forged 292 hd truck crank, .020 main, .040 rods, stock stroke 3.3
Mummert forged connecting rods & push rods
Diamond blower pistons w/total seal 1.5, 1.5, 3.0 blower ring pack,
Clevite rod & main bearings, Ted Eaton special cam brg.
main bearing girdle/ scraper fabricated per Ted eaton blueprints
factory oil pump, pick-up, & truck pan
Cam& lifters by Oregon cam grinding to Ken Heard specs
Mummert aluminum cylinder heads modified to fit beehive springs & oversize ex.valves
 Harlan/sharpe 1.6 ratio roller rockers
FPP double roller timing chain
Rotating assy. balanced by Ten Eaton specialties
Factory Y block distributor converted to dura spark, curved by Faron Rhodes
Blower& drive assembly by Deans Blowers out of Washington state, old school blower
Intake manifold & crank adaptor from Y-bloke enterprizes in walla walla Australia
950 holley 3rl
1956 Ford Gasser 427FE
1966 Fairlane
1966 Bronco supercharged
Re: FE-older brother Y
« Reply #1 on: April 10, 2019, 06:20:39 AM »
Look at that torque curve, that thing is gonna come on like a freight train. Awesome!! :o. Dont know alot about those blocks at .050 is that alot for those blocks or are they thicker than an FE.
« Last Edit: April 10, 2019, 06:31:41 AM by Stangman »
« Reply #2 on: April 10, 2019, 07:50:29 AM »
I think that's a 525 HP engine if you rev it a little higher, Dean.  Great job!
« Reply #3 on: April 10, 2019, 09:39:51 PM »
As with any old block, water sitting over time can rust the liners, and it is always a good idea to sonic test any of them before going very much over standard.  Most can go +.060", but occasionally one is paper thin at +.030".  My 2018 EMC 292 block is bored +.132" after sonic testing and offset boring.  I have two 292 blocks that are +.040" and will be pushing  the maximum at +.060".  One 292 that is going to be good to .+125", so sonic testing is worth the time and money.  Joe-JDC
« Reply #4 on: April 11, 2019, 11:06:10 AM »
Thank You Joe!
DEANs427
« Reply #5 on: April 11, 2019, 05:11:19 PM »
Y block sonic test results:
1966 Fairlane
« Reply #6 on: April 11, 2019, 07:11:53 PM »
Nice thanks for the test, pretty good meat.
Royce
« Reply #7 on: April 14, 2019, 11:39:25 AM »
Dean the Blown 292 must make close to the power your 427 made..  Watch out FEs !  Y Blocks: Torque of a locomotive, RPM of a die grinder. And every one is a side oiler...
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam.
1968 Cougar XR7
« Reply #8 on: April 14, 2019, 11:53:53 AM »
I'm shakin' in my boots - not  ;D  Royce, I see you are spouting the Y-block party line  ;D
« Reply #9 on: April 15, 2019, 05:52:28 AM »
Dem sounds like fightin words, maybe a 332 FE against a 292 Y bock is in order one of these days!!!???. ;) 8)
Royce
« Reply #10 on: April 15, 2019, 07:40:21 AM »
I am all in!   I have a 333 Y block itching for a fight
1992 BMW V-12 5.0
1968 Cougar XR7
DEANs427
« Reply #11 on: April 15, 2019, 09:48:21 AM »
"Its not the size of the dog (motor) in the fight, its the size of the fight in the dog", applies here
1966 Fairlane
« Reply #12 on: April 15, 2019, 12:50:23 PM »
Can I bring my "lil" 292 to this competition?  Joe-JDC
DEANs427
« Reply #13 on: April 15, 2019, 01:55:06 PM »
As for comparing dyno numbers, Jay probably has a couple of my 427 numbers in his archives.
Don't forget to compare these numbers, thick FE 427 block $4000+, thick Y block $100, FE forged steel crank $1000, forged steel $ sign Y crank $200
This does appear to be a call-out, when I first started the Nostalgia, heads-up racing with the gasser I got called out quite often, usually by shiny chebbies, after the first couple of seasons there were not very many call-outs any more...
Joe, bring your Y out for sure !
1966 Fairlane
« Reply #14 on: April 15, 2019, 02:16:00 PM »
Great, something else to sidetrack Jay lol. He will never get those heads done
« Reply #15 on: April 15, 2019, 02:25:58 PM »
Dean you dont happens to have a link to the Ybloke enterprizes
cant find him. I happens to have a few Y-blocks and a 4/71 wheighting
down the shelfs :)
DEANs427
« Reply #16 on: April 15, 2019, 03:50:28 PM »
Heo,
on Facebook, search YBloke or Lindsay Shoemark, (no space between Y and Bloke)
I heard he is working on a installation kit with all the parts needed for the conversion..
my parts got to the states in a week but took over 2 weeks to clear US customs,
excellent casting and machine work.
if you order, be sure to order his crank pulley and adaptor if you opt for the big belt..
« Last Edit: April 15, 2019, 03:52:03 PM by DEANs427 »
1966 Fairlane
« Reply #17 on: April 15, 2019, 04:30:23 PM »
Thanks Dean
Royce
« Reply #18 on: April 15, 2019, 07:54:39 PM »
I see a trend.. which could become a movement.. Which could become a....
1992 BMW V-12 5.0
1968 Cougar XR7
57 lima bean
« Reply #19 on: April 15, 2019, 09:53:11 PM »
A blower with high swirl heads?The combustion chamber must be like a centrifuge.
Royce
« Reply #20 on: April 16, 2019, 08:21:09 AM »
The Y Block power production certainly does make your head spin!  Can a Hi Swirl FE head be far behind? As out resident y block guru J.C. always says  "There is magic in those over/under ports".  LOL
1992 BMW V-12 5.0
1968 Cougar XR7
« Reply #21 on: April 16, 2019, 07:35:44 PM »
Royce what do you mean by a high swirl head do you have any photos
« Reply #22 on: April 16, 2019, 09:12:55 PM »
LOL High Swirl means low flow  ;D ;D
Royce
« Reply #23 on: April 17, 2019, 02:21:24 PM »
Actually High swirl in not completely accurate.. The Y block has a Ricardo chamber which is more high turbulence than swirl.  The purpose was to prevent detonation from the sketchy fuels available in the early 50s . Turbulence gives a more homogeneous mixture of fuel and air and also reduces the amount of timing required for max torque. Where a small scrub needs as much as 40 degrees, I have never dynoed a Y block that needed more that 34 degrees..
Flow....  Not so fast Prof. Brown..  A stock G  head  on a 292 Y block  flows about .75 cfm/cu. in.  A 428 CJ head flows closer to .5 cfm/cu in
1992 BMW V-12 5.0
1968 Cougar XR7
57 lima bean
« Reply #24 on: April 18, 2019, 01:03:42 PM »
"Ricardo chamber"....Jay will counter with "You may be on Fantasy Island".Selling the Mermaid will allow you to repair the Ohio/Peruvian designed engine.
Royce
« Reply #25 on: April 19, 2019, 08:32:57 AM »
Peruvian??
1992 BMW V-12 5.0
1968 Cougar XR7
« Reply #26 on: April 20, 2019, 12:02:57 PM »
Leema, as in Lima, Peru, or Lyma as in Lima, Ohio?  The 429-460 engines were nicknamed "Lima" by some instead of 385 series.  Joe-JDC
Royce
« Reply #27 on: April 21, 2019, 09:39:53 AM »
Thanks Joe for nailing that down.. Steve's references sometimes get a little obscure and tangential.. I should have figured it out but was hung up on Andes mountains and the Inca empire...
1992 BMW V-12 5.0
1968 Cougar XR7
Joey120373
« Reply #28 on: June 16, 2019, 10:25:06 PM »
I’ve got a 330 (331) truck block that was running with a dodge Cummins turbo when I parked it.
Needs a freshening up but it would be fun to have a friendly grudge match.
Boost optional....
falcongeorge
« Reply #29 on: June 17, 2019, 10:22:25 AM »
"Like" button needed!!! ;D ;D
