Author Topic: FE-older brother Y  (Read 19917 times)
Re: FE-older brother Y
« Reply #15 on: April 15, 2019, 02:25:58 PM »
Dean you dont happens to have a link to the Ybloke enterprizes
cant find him. I happens to have a few Y-blocks and a 4/71 wheighting
down the shelfs :)
DEANs427
« Reply #16 on: April 15, 2019, 03:50:28 PM »
Heo,
on Facebook, search YBloke or Lindsay Shoemark, (no space between Y and Bloke)
I heard he is working on a installation kit with all the parts needed for the conversion..
my parts got to the states in a week but took over 2 weeks to clear US customs,
excellent casting and machine work.
if you order, be sure to order his crank pulley and adaptor if you opt for the big belt..
« Last Edit: April 15, 2019, 03:52:03 PM by DEANs427 »
1956 Ford Gasser 427FE
1966 Fairlane
1966 Bronco supercharged
« Reply #17 on: April 15, 2019, 04:30:23 PM »
Thanks Dean
Royce
« Reply #18 on: April 15, 2019, 07:54:39 PM »
I see a trend.. which could become a movement.. Which could become a....
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
57 lima bean
« Reply #19 on: April 15, 2019, 09:53:11 PM »
A blower with high swirl heads?The combustion chamber must be like a centrifuge.
Royce
« Reply #20 on: April 16, 2019, 08:21:09 AM »
The Y Block power production certainly does make your head spin!  Can a Hi Swirl FE head be far behind? As out resident y block guru J.C. always says  "There is magic in those over/under ports".  LOL
1992 BMW V-12 5.0
« Reply #21 on: April 16, 2019, 07:35:44 PM »
Royce what do you mean by a high swirl head do you have any photos
« Reply #22 on: April 16, 2019, 09:12:55 PM »
LOL High Swirl means low flow  ;D ;D
Royce
« Reply #23 on: April 17, 2019, 02:21:24 PM »
Actually High swirl in not completely accurate.. The Y block has a Ricardo chamber which is more high turbulence than swirl.  The purpose was to prevent detonation from the sketchy fuels available in the early 50s . Turbulence gives a more homogeneous mixture of fuel and air and also reduces the amount of timing required for max torque. Where a small scrub needs as much as 40 degrees, I have never dynoed a Y block that needed more that 34 degrees..
Flow....  Not so fast Prof. Brown..  A stock G  head  on a 292 Y block  flows about .75 cfm/cu. in.  A 428 CJ head flows closer to .5 cfm/cu in
1992 BMW V-12 5.0
57 lima bean
« Reply #24 on: April 18, 2019, 01:03:42 PM »
"Ricardo chamber"....Jay will counter with "You may be on Fantasy Island".Selling the Mermaid will allow you to repair the Ohio/Peruvian designed engine.
Royce
« Reply #25 on: April 19, 2019, 08:32:57 AM »
Peruvian??
1992 BMW V-12 5.0
« Reply #26 on: April 20, 2019, 12:02:57 PM »
Leema, as in Lima, Peru, or Lyma as in Lima, Ohio?  The 429-460 engines were nicknamed "Lima" by some instead of 385 series.  Joe-JDC
Royce
« Reply #27 on: April 21, 2019, 09:39:53 AM »
Thanks Joe for nailing that down.. Steve's references sometimes get a little obscure and tangential.. I should have figured it out but was hung up on Andes mountains and the Inca empire...
1992 BMW V-12 5.0
Joey120373
« Reply #28 on: June 16, 2019, 10:25:06 PM »
I’ve got a 330 (331) truck block that was running with a dodge Cummins turbo when I parked it.
Needs a freshening up but it would be fun to have a friendly grudge match.
Boost optional....
falcongeorge
« Reply #29 on: June 17, 2019, 10:22:25 AM »
"Like" button needed!!! ;D ;D
