Author Topic: What Did You Promise;...Your FE This Year ?  (Read 17384 times)
427HISS
« on: January 11, 2019, 09:54:40 PM »
Mine is to finish,....building my 428.   ;D
chris401
Re: What Did You Promise;...Your FE This Year ?
« Reply #1 on: January 11, 2019, 11:15:05 PM »
I threatened to replace it with a MEL several years ago but the 352 has been so dependable I promised it an overdrive this year.
Bolted to Floor
« Reply #2 on: January 11, 2019, 11:49:42 PM »
TO DRIVE IT!!!! Clocked about 2000 miles since I got it going.
Headed to Luckey’s Rod Run in College Station this weekend with guys from the MustangSteve forum.
« Reply #3 on: January 12, 2019, 12:04:32 AM »
To sniff a little NOS
« Last Edit: January 13, 2019, 01:50:21 PM by fekbmax »
« Reply #4 on: January 12, 2019, 06:09:38 AM »
I plan to replace my 428 with a stroked 427.  The plan is to run just as fast, but with less rpm, less gear, and less stall.
paulie
GJCAT427
« Reply #5 on: January 12, 2019, 08:36:44 AM »
Which one?  My 427 in my Galaxie , to replace the old one with a new Tunnel Port version. Its currently sorta on track for Beaver Springs.  The 56 f 100, may be change out the BJ/BK twin carbs for a set of BC/BDs that I have setting on the shelf.
Thumperbird
« Reply #6 on: January 12, 2019, 09:57:19 AM »
One step warmer plug
Better gasket matched intake/heads, found some 1/16" gasket lips in there I did not like
Properly aligned valvetrain, jacked the rocker arms up .25", new pushrods
Valve cover oil leak
Version 2.0 of adaptor spacer for Holley twins on Edelbrock intake, preserving the dual plane all the way up to the carbs, delete the 4 hole and reduce the adaptor angle
Set of Quick Fuel 600's so I can see how another set behaves and swap the BJ/BK's in and out
PCV valve
Air filters to let it breath better
Reduce the stall on converter from 3100 to 2700/2800
The thing winds out really well albeit a bit lean, need more bottom end.
Thanks
MRadke
« Reply #7 on: January 12, 2019, 10:39:23 AM »
To finally install the headers that I bought 2 years ago and had ceramic coated last year.
« Reply #8 on: January 12, 2019, 06:29:44 PM »
i already got my 428 plenty of presents,but i told my 66 comet im putting my 4 speed back in it.i changed a 4 speed car over to a c6 years ago.its about time the third pedal came back into play.
George vega
« Reply #9 on: January 13, 2019, 12:52:30 PM »
To finish the new 416 co fe for the race car and get back on the track. ;D
68 Mustang Cobra Jet tribute Race Car
6667fan
  • Every Second Counts
« Reply #10 on: January 14, 2019, 12:46:53 PM »
Due to a broken exhaust valve my 483 was shut down in September.  I repaired the P block the engine was built on but will be going with a NOS 71 427 service block for the next go ‘round
Strongly considering going sold roller for this iteration. Should be able to re-use the Scat forged 4.25 stroke crank and the H beam rods.
JB
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #11 on: January 14, 2019, 01:11:12 PM »
An oil change?   That's about it for the wagon.  The clutch is getting a quick service, might split the transmission and recheck things.  Beyond that, Nadda, nuthin.
« Reply #12 on: January 14, 2019, 02:16:45 PM »
Got my BT 2x4 intake to put on. And maybe a rotor phase and an oil change and pray it runs good. :) 8)
shady
« Reply #13 on: January 14, 2019, 04:04:12 PM »
We'll see what you say after the Beave.  As for me, my FE plate is full. Engines to build, change, and all around mayhem. I can't have just one, nope. Damn bucket list.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
6667fan
« Reply #14 on: January 14, 2019, 07:10:27 PM »
Stangman, you got a used MSD cap there for the phase job?
I have some available.
JB
JB
67 Fairlane 500
482 cid 700/617
