Author Topic: 1967 fastback 485  (Read 147277 times)
Re: 1967 fastback 485
« Reply #75 on: October 14, 2019, 08:06:17 PM »
Yeah Doug that’s what I’m worried about, I guess I will be doing some measuring. To bad there aren’t any specs that I can measure against
The 1967 Ford Mustang Shop Manual has the pertinent body measurements you can check against.
« Reply #76 on: October 14, 2019, 09:44:54 PM »
Awesome thanks Kevin that’s a big help.
« Reply #77 on: October 15, 2019, 08:06:09 PM »
So I didn’t get to take car out of trailer but did take carbs off and check for dirt in intake and although there was a dusting on carbs it looks like I dodged a Bullit. Put carbs back on a fired her up all seems good. Went to shut off key and it won’t turn off like I’m not turning switch. Seems like I need an ignition switch. I disconnected dizzy to get it to turn off but fuel pump still running, I had to disconnect battery. I know the car got banged around but for the ignition switch to go bad is weird. Anybody think it could be anything else.
« Reply #78 on: October 20, 2019, 05:21:33 PM »
Joe I haven’t read the whole thread. Is your ignition through an MSD box?
If so and IIRC (which is always suspect) I had to install a relay in line to get my truck to work consistently.
« Reply #79 on: October 21, 2019, 07:30:18 AM »
I am running an MSD6AL. IIRC whats that. This is the second time this has happened to me in like 2.5 to 3 years.
Maybe three times I always change the ignition switch and it works but maybe something is making them crap out.
« Last Edit: October 21, 2019, 07:50:11 AM by Stangman »
Russ67Scode
« Reply #80 on: October 21, 2019, 01:19:13 PM »
Do you have an electric fan on the radiator?  I had the same problem with an AC cobra I had some years ago  either shut off the fan first or find a way to isolate it from your ignition / key switch
BP 520 ci BBM Twin turbo FAST EFI
« Reply #81 on: October 21, 2019, 01:29:23 PM »
I do have an electric fan that runs off of a temp switch. So your saying put a toggle in between to shut power off.
Russ67Scode
« Reply #82 on: October 24, 2019, 08:32:17 PM »
YES
« Reply #83 on: October 25, 2019, 06:57:29 AM »
Thanks will try that
« Reply #84 on: August 30, 2020, 07:01:15 PM »
First to Russ67scode the not shutting off with the key you told me to take a look at my electric fans. Well it was my fuel pump so thank you for steering me in the right direction. I shut it off before I shut the car off.
Well anyway went out today to make sure the car was ok after my 4 wheel drive spectacle. I ended up needing a lower control arm and strut rod so of course I got both and a rim and 2 tires and a wheel alignment.
First pass I ran an 11.15 @ 121.44 it felt good but I felt a little on guard because of going off the track.
Second pass I ran an 11.14 @ 121.37 I really thought I might get into the 10s but maybe it’s not in the cards. But I was happy that it was consistent and the car went straight.
So FE reunion here we come!
« Reply #85 on: August 30, 2020, 09:07:58 PM »
Great news.  That 10 second pass is gonna happen as the good fall air comes in.
« Reply #86 on: August 31, 2020, 11:28:45 AM »
Get an oil pressure shutoff switch for that fuel pump too.
« Reply #87 on: August 31, 2020, 01:11:52 PM »
What exactly do you mean Drew. Do you mean in case of rollover. And if that is what you mean do you have one in mind.
« Reply #88 on: August 31, 2020, 10:47:56 PM »
I’d have to look it up.
Mine is from Carter. Shuts the engine off anytime there is less than 6psi oil pressure. Takes 5 minutes to plumb in. Nice piece of mind tho.
« Reply #89 on: August 31, 2020, 10:56:54 PM »
Carter A68301
