Author Topic: Finalized my path on 67 mustang project  (Read 43376 times)
Russ67Scode
Re: Finalized my path on 67 mustang project
« Reply #30 on: December 04, 2016, 12:29:05 PM »
ScotiaFE that was leaving at 1800 rpm ! Steel flywheel 5 speed and 4.57 gears, .030 390 ported edelbrocks factory dual quad intake hooker headers and a 25 yr old comp cam
I think I have the chassis working pretty good for now
Plan is for a 8 point cage
« Reply #31 on: December 04, 2016, 01:15:24 PM »
Make sure you got it nailed down hard.
That 520 incher will do some bucking if not. ;)
Russ67Scode
« Reply #32 on: December 04, 2016, 04:54:26 PM »
We are going to work with some solid motor mounts and a bar on the drivers side after all the turbo piping is installed
What's funny is talking to Blair and he says this should be interesting
ec164
« Reply #33 on: December 04, 2016, 10:21:49 PM »
Very cool project, look forward to seeing it done and flying.....Al
You're ahead in a Mercury......all the way
Russ67Scode
« Reply #34 on: December 19, 2016, 08:04:08 PM »
Got most of the fuel system finished up this is all moving much slower than I had anticipated
Working for a living is getting in the way of my car habit
I forgot how much I hated making up braided line
« Last Edit: December 19, 2016, 08:15:55 PM by Russ67Scode »
Russ67Scode
« Reply #35 on: December 20, 2016, 09:00:41 AM »
I do have a small problem. The pushin filler cap or in my case the crankcase evac cap hits the export brace   So another set of VC's should fix this but which set ? Are the Aluminum CJ style much shorter ?  Or get the BT with the holes up front ?
Russ67Scode
« Reply #36 on: May 31, 2017, 01:53:42 PM »
So the engine was ran on the Dyno
520 ci BBM heads and block. Small hyd. Roller cam (idles at 800 rpm) 9 to 1 compression on 93 octane, locked out timing at 32 deg.  662 tq and 617 hp. Next comes a pair of 69 mm turbos and EFI
« Reply #37 on: June 01, 2017, 07:19:58 AM »
Russ, looks like you've got a bit of torque to spare on that one! And a nice wide torque band too. With 2 turbos added, and EFI, that should make for a very VERY interesting ride. I hope you have lots of clean underwear! ;D
« Reply #38 on: June 01, 2017, 08:06:29 AM »
Wow
All that naturally aspirated power in a 1st gen mustang. You're a sick man adding turbos.
I LOVE IT
Russ67Scode
« Reply #39 on: June 01, 2017, 01:05:32 PM »
Too funny  had the same statement about my 32 bantam 351C and fogger NOS system, and the fox body mustang with a kaase headed 514 ci
« Last Edit: June 01, 2017, 01:08:47 PM by Russ67Scode »
Joey120373
« Reply #40 on: June 03, 2017, 08:32:05 AM »
Wow, that is a monster now, going to be a bit insane with the turbos... I noticed the A/F ratio looked a bit rich on the dyno sheet, was that on purpose for the turbo tune? looks like its in the mid 11-1 for most of the pull, usually you would want that to be 12.5-13 ish wouldn't you?
Your N/A motor is very similar to what i am planning for my old truck, 520ci, small cam etc.
I'm planning on a bit more compression and a set of pro-port heads, so should put up about the same numbers, with a bit of a bump from the compression.
Thanks for posting all the pics, that thing is epic.
Joe
« Reply #41 on: June 03, 2017, 10:49:45 AM »
Usually with a supercharged or turbocharged engine you want to run a bit rich,  11.5-12.0 or so.  I think his A/F is spot on for a blower application.
Russ67Scode
« Reply #42 on: June 03, 2017, 12:27:05 PM »
Agree but this dyno chart was NA just to check out the engine
I have a FAST EFI system in the car now so Blair just ran a carb he had on hand , also dist was locked at 32 deg.   We didn't care about all out power as the set up with the turbo's will come together in my mustang . So I am sure there is some more in it but under boost the NA numbers are going to be weak
Joey120373
« Reply #43 on: June 03, 2017, 02:36:27 PM »
you and i have vastly different opinions of "weak"..... 8)
CaptCobrajet
« Reply #44 on: June 03, 2017, 05:46:36 PM »
Joe
We purposefully used lower static c/r, and also the ports, both intake and exhaust are VERY large.   I wanted the big port volumes and the compression to compliment the finished product.  I left it a little rich on purpose, because as Jay said, the "tune" on the EFI will be a little richer for WOT.  Not so much for the part throttle tune.  I'll use a little less cam, and a little more static on yours Joe, and the SPP port volumes will probably bump closer to 700/700 for peaks on a purpose-built truck thumper.  The SPP move the same air....a little more actually,  as the CNC BBMs with more than 20 less CCs in the intake runner......
« Last Edit: June 03, 2017, 09:46:06 PM by CaptCobrajet »
Blair Patrick
