Author Topic: Finalized my path on 67 mustang project  (Read 43365 times)
Russ67Scode
Re: Finalized my path on 67 mustang project
« Reply #60 on: November 24, 2017, 05:45:31 PM »
A little update on the project
Had to remove the car from the shop that was doing the header install , after approx 6 months and $4500 I had a set of motor mounts 5 tacked together tubes and my intercoolers tacked together and set in front of the radiator, at that rate it would have been done in January and around $10000
So this was my most expensive lesson ever
Russ67Scode
« Reply #61 on: November 24, 2017, 05:51:10 PM »
More pics
« Reply #62 on: November 24, 2017, 06:05:09 PM »
Annoying, sorry you have to deal with that.
How's your welding skills? It looks at least like you have a pattern to work with, if it's fitting so far.
Lot to be said for doing it yourself, though I completely understand having someone do it because of time/family/skill/room and a hundred other reasons.
Russ67Scode
« Reply #63 on: November 24, 2017, 06:26:09 PM »
Thanks
 I can weld but don’t have the equipment to weld stainless and dont have a pipe bender
« Reply #64 on: November 25, 2017, 01:38:36 AM »
Ok those are two more reasons, but, there are stainless mandrel bent tubing kits out there so you don't need a bender. You can just make cuts.
Wish you lived closer to me, I could turn you on to a good honest guy.
Anyway good luck with it. Anxious to see it done.
