Author Topic: Finalized my path on 67 mustang project  (Read 43436 times)
Russ67Scode
Re: Finalized my path on 67 mustang project
« Reply #15 on: October 15, 2016, 02:26:52 PM »
Got the rear bolted in
edgarval
« Reply #16 on: October 15, 2016, 08:46:32 PM »
I can not wait either . Great car/engine . What stroke are you going with
Russ67Scode
« Reply #17 on: October 15, 2016, 09:32:32 PM »
Edgarval 4.345 X 4.375 B/S
Gears are 4.57 W/Detroit locker in the above pic
« Last Edit: October 15, 2016, 10:28:23 PM by Russ67Scode »
Russ67Scode
« Reply #18 on: December 03, 2016, 10:35:35 AM »
Started to assemble the intake and injectors, fuel rails say 3/8 NPT. Bought 3/8 NPT to AN-8 fittings and they don't fit any ideas. They are edelbrock fuel rails
Thanks Russ
SICTSIX
« Reply #19 on: December 03, 2016, 10:48:15 AM »
This thing should be nasty !!
C.Norris
Denver,Colorado
1966 Fairlane GTA 462 ci
1966 Fairlane XL 562 ci
« Reply #20 on: December 03, 2016, 03:22:53 PM »
Sweet.
Watching along as my '66 is going down a similar path.
Edit
As I read more....not so much LOL
« Last Edit: December 04, 2016, 05:05:35 PM by turbohunter »
« Reply #21 on: December 04, 2016, 06:16:24 AM »
Thanks Russ
Me thinks the hole is 1/4" pipe in the fuel rail.
So 1/4" NPT to AN 8 should work.
Kool Car!
« Reply #22 on: December 04, 2016, 06:22:10 AM »
I notice that you do not have the spring perches welded up.
They need to be boxed in or you will have a failure and it will happen.
Not a big deal, but needs to be done. :)
Still a KOOL CAR!
« Reply #23 on: December 04, 2016, 08:16:56 AM »
Looking good, Russ.  On the fuel rails, most of the ones I've seen use a straight thread, not a pipe thread, with an O-ring seal.  A #8 AN is common.  Can you screw the AN side of your fitting into the rail?  If not, is it too big or too small?
Russ67Scode
« Reply #24 on: December 04, 2016, 08:21:15 AM »
I plan on moving the spring perches in if I move the leafs for a bigger tire , but I will weld them up either way thanks
« Last Edit: December 04, 2016, 08:25:23 AM by Russ67Scode »
Russ67Scode
« Reply #25 on: December 04, 2016, 08:26:57 AM »
I grabbed a -6 O Ring fitting it screwed right in   So I guess I will order another 4 fittings
Russ67Scode
« Reply #26 on: December 04, 2016, 08:33:31 AM »
Here is a page from the edelbrock web site
This is why I ordered 6 fittings in 3/8 NPT (2 90 deg and 4 straight fittings)
« Reply #27 on: December 04, 2016, 08:56:47 AM »
Way Kool Launch!
Now this is just some thinking, but I would consider the Shelby drop on the front to correct the wheel spazz.
And if they are not in yet a full set of some heavy duty rails under the seats.
Maybe even a hoop and door bars.
The thing is going to take off in the air.   ;D
« Reply #28 on: December 04, 2016, 09:00:36 AM »
Apparently they have lied to the internet. Interesting. :)
« Reply #29 on: December 04, 2016, 11:43:20 AM »
Yes, what a surprise.  You never see that  ;D ;D
