Author Topic: 1964 Comet Blown injected Cammer  (Read 145209 times)
gdaddy01
Re: 1964 Comet Blown injected Cammer
« Reply #105 on: January 27, 2021, 09:43:03 AM »
that engine has already scared the drive shaft lose from the rear end . glad you found the problem with the brakes .
« Reply #106 on: February 02, 2021, 01:36:55 PM »
do you know about how much power that engine is going to make?
« Reply #107 on: February 02, 2021, 03:20:41 PM »
Also need to remember that Wilwoods need to be bled from both inside and outside.  The two sides do not communicate.  Took somebody an afternoon to realize that....
« Reply #108 on: February 02, 2021, 03:24:31 PM »
I think you and I had the same experience Barry ;)
Leny Mason
« Reply #109 on: February 03, 2021, 09:38:26 AM »
Thanks, My Wife and I bleed and bleed, it still made air then it started to leak out of the front of the master cylinder, so they are sending me a new one and a spare we hope this fixes it, the headers are all tacked together so out with the engine and get ready to start it.
Leny Mason
« Reply #110 on: February 08, 2021, 04:34:45 PM »
I made drain plugs that except Bosh style knock censors, and we are going to try them there in the block drain plugs I hope the will work there Leny.
Leny Mason
« Reply #111 on: May 09, 2021, 09:39:08 AM »
Sanding and buffing on the firewall and fender wells, it looked great before, I must have a mental issue but it is shinning nice.
Leny Mason
« Reply #112 on: May 09, 2021, 09:46:00 AM »
Wiring the engine it has a lot of wires, then I put thermal couples on each cylinder for temperature readings two more wires on each cylinder.
Leny Mason
« Reply #113 on: January 30, 2022, 05:36:09 PM »
I got My water outlet made I have been fighting with it trying to make something that looked nice, I am happy with it now getting closer.
« Reply #114 on: January 31, 2022, 06:20:59 PM »
lenny I dont want to go back and read the whole thing. Do you know what shes gonna make HP wise.
Leny Mason
« Reply #115 on: February 01, 2022, 12:05:46 AM »
We are going for 1100, I am going to start it on race fuel and wean it to pump gas I hope, that is My plan thanks, Leny.
KMcCullah
« Reply #116 on: February 01, 2022, 07:53:11 AM »
Little details take time. Lookin sharp, Leny. Can't wait to see the tire smoke.  8)
Kevin McCullah
Tommy-T
« Reply #117 on: February 01, 2022, 12:28:02 PM »
Good to see progress, Leny.
That cammer is baddazz! Hope to see it out here at Bakersfield.
My Comet is still in paint jail. I hope to have it home soon so I can finish it up.
Don't wipe all the paint off of the firewall or you'll have to paint it again! ;)
« Reply #118 on: February 01, 2022, 07:12:52 PM »
thats gonna be a bad bitch
Leny Mason
« Reply #119 on: February 02, 2022, 09:43:53 AM »
Parts are fitting well now, every thing has to be modified in some way it seems like I have bought two of everything trying to make them fit.
