Author Topic: Billet Sheet Metal Style Intake Manifold for the FE Intake Adapter  (Read 50263 times)
Re: Billet Sheet Metal Style Intake Manifold for the FE Intake Adapter
« Reply #60 on: March 11, 2018, 01:30:09 PM »
Really cool pieces Jay!
is this 1st intake designed for a Hi-Riser (primarily) or, with your adaptor, do you think it would work as well with other traditional iron and aluminum heads? Guesstimate on the manifold's weight versus a pure sheet metal intake?
« Reply #61 on: March 11, 2018, 02:15:32 PM »
Any plans on making a top for 4500 series carbs or possibly a made to order kinda thing ?
« Reply #62 on: March 11, 2018, 02:47:23 PM »
Bob, the one I just posted is designed for low riser and medium riser heads, on my #13001 intake adapter.  It will also fit directly on a 351C with stock heads, although you would have to use one of those pans over the valley, since there is no bottom on the intake.  So, I can now do these billet intakes for any FE (LR, MR, HR, or Tunnel Port) except the SOHC, and I do plan to do an SOHC version in the near future.   As a guess I would say that the billet intake is probably 10-12 pounds heavier than a sheet metal intake.
Keith I would do a top like that for a pair of Dominators if I get an order for one.  It would take me a little extra time because the design and CNC code would have to be modified, of course, but it wouldn't be a big deal to do that.
« Last Edit: March 11, 2018, 02:59:47 PM by jayb »
Joey120373
« Reply #63 on: January 13, 2019, 11:44:44 AM »
Just looking through this thread again because its so darn cool.
Do you have any plans to dyno this type of manifold on the 504 mule?
« Reply #64 on: January 13, 2019, 01:44:27 PM »
Yes I do, planning for this spring - Jay
