Author Topic: 1967 Fairlane Super Stock  (Read 204298 times)
GPR
    • Gillis Restorations
« on: August 22, 2013, 11:11:14 AM »
I started this project a long time ago and I believe at this time we will be building it with a 390 to race in SS/IA or SS/JA. Modified Mustangs & Fords magazine will be featuring tech articles in upcoming issues.
This is how it looks right now without the front fenders buffed.
This is what we started with and I will catch you up on the build as time permits
Rusty Gillis
Former NHRA SS/FA & SS/GA National Record Holder
Re: 1967 Fairlane Super Stock
« Reply #1 on: August 22, 2013, 11:25:31 AM »
Man, that baby is RED!  Looks great Rusty, can't wait for more details...
GPR
« Reply #2 on: August 22, 2013, 11:29:25 AM »
Thanks Jay I painted it in our shop using SPI red.
www.southernpolyurethanes.com
Rusty Gillis
amdscooter
« Reply #3 on: August 23, 2013, 01:40:02 PM »
Sporting a serious case of paint job envy over here.... that thing looks like it was dipped in candy! Be sure to keep us updated!  ;)
GPR
« Reply #4 on: August 23, 2013, 04:35:18 PM »
Other than the bad quarter the car was pretty solid only needed a few patches.
We cut out the floor
2 x 2 subframe connector from the rear torque box to the front torque box and tying into the rocker and also a place to weld the roll cage.
« Last Edit: August 23, 2013, 04:44:45 PM by GPR »
Rusty Gillis
« Reply #5 on: August 23, 2013, 07:48:41 PM »
Thanks for posting those floor pix.
I'm dead in the middle of that right now.
GPR
« Reply #6 on: August 25, 2013, 12:45:09 PM »
Rusty Gillis
« Reply #7 on: August 25, 2013, 01:39:08 PM »
Very nicely done!!!
GPR
« Reply #8 on: August 27, 2013, 01:07:33 PM »
At the time I did not want to spend around $700 for a new quarter so I straightened it.
Sprayed a couple of coats of Slick Sand Polyester primer over SPI black epoxy primer
Block sanded to find the highs and lows. Primed and blocked a few times
I would have been better off with a new quarter would have saved a lot of work.
Rusty Gillis
« Reply #9 on: August 27, 2013, 03:07:09 PM »
Thanks again
Since you posted all those pics I have decided to cut out the front floor a bit in order to access the welding needed.
BTW my connectors weld to the trans mount rails instead of going to the torque box as yours do.
Any thought on that?
BTW
Nice work
« Last Edit: August 27, 2013, 03:10:19 PM by turbohunter »
« Reply #10 on: August 27, 2013, 09:06:45 PM »
BTW
Nice work
I think I'd extend to the torque box if I were you; that is where most of the strength is on the unit body cars.  I always run from the rear subframe all the way to the torque box, and tie to the front subframes along the way.
dmazz
« Reply #11 on: August 28, 2013, 10:28:04 AM »
Well Done, Can't wait to see it runnin.
GPR
« Reply #12 on: August 28, 2013, 05:19:20 PM »
Welded all around the shock tower
Welded the holes not needed in the firewall. Even welded by mistake the throttle linkage holes!!
Sanded the engine compartment down to bare metal and ground the welds on the firewall.
Sprayed two coats of SPI black epoxy.
Rusty Gillis
« Reply #13 on: August 28, 2013, 06:53:01 PM »
Beautiful job on that engine compartment, Rusty...
GPR
« Reply #14 on: August 31, 2013, 09:20:04 AM »
We are building this old school with leaf springs and CalTracs.
My son Brian does all the fabrication so I had him mini tub it.
I did a little bodywork
Rusty Gillis
