Author Topic: 1967 Fairlane Super Stock  (Read 204295 times)
Russ67Scode
Re: 1967 Fairlane Super Stock
« Reply #180 on: September 22, 2019, 08:46:39 AM »
Made a few pulls on a hub dyno it made 630 hp at the wheels on 3 lbs of boost !  750 + at 7 lbs with little timing 19 deg
And then we tried some more boost read below
About 4000 rpm It started to loose fuel pressure it went from 45 to about 36 lbs   The computer drove the injectors to 100 % trying to keep fuel
But it did make almost 900 ft/lbs of tq at 3549 rpm , with 19 deg of timing also ! The graph looked like a nitrous shot it was headed almost straight up ! All this on a hub dyno. Pretty good for my first try at EFI !!  Thanks Blair Patrick for a killer engine !
Video
https://youtu.be/ZxMMfmqYOS4
« Last Edit: September 22, 2019, 09:01:42 AM by Russ67Scode »
Gregwill16
« Reply #181 on: September 22, 2019, 10:59:37 AM »
Very nice great job!
Russ67Scode
« Reply #182 on: November 08, 2023, 06:50:07 PM »
Good day at the races got a transbrake installed. Thanks Jim Paquet !
it really liked that best 60 ft was 1.36 was a bracket race 1/8 th mile ran a 6.0 letting out early as not to break out.    The track said no laptop in the passenger seat.  so no data logs. ran pump gas  really rich and 22 deg of timing 7 lbs boost
« Last Edit: November 08, 2023, 06:53:26 PM by Russ67Scode »
« Reply #183 on: November 09, 2023, 12:14:33 AM »
Nice she’s coming along nice Russ. 900 lb/ft sweet.
hbstang
« Reply #184 on: November 11, 2023, 02:19:27 PM »
funny,4 years ago,wonder how its doing now.
recent video
https://www.youtube.com/watch?v=Y1fnHXJGSAA
« Last Edit: November 11, 2023, 02:22:34 PM by hbstang »
Russ67Scode
« Reply #185 on: December 08, 2023, 08:57:44 AM »
Funny you found that video. It was running on 5 good cylinders that pass. it had broke a rocker adjustier and stuffed the pushrod into the aluminum rocker. had a few other valve train problems also.  listen to the engine sounds terrible !!
12-09-23 we are headed out to the track for T N T and trying some E-85
Russ67Scode
« Reply #186 on: December 10, 2023, 08:54:30 AM »
So the swap to E-85 complete. on my old 93 tune (modified for E-85) and added 1 deg timing (23 deg) this is at 7 lbs of boost !  3610 lbs with me in it.
9.33 @ 145.75 mph
hbstang
« Reply #187 on: April 03, 2024, 10:56:41 AM »
fast fe for sure.what fuel pump regulator are you using with e85? are you going to drag and drive events?if you knock some weight off that would be in the 8s with low boost!
Russ67Scode
« Reply #188 on: April 03, 2024, 05:53:52 PM »
the pressure regulator is an aero motive boost reference return style
I did sick week in Florida. but ripped the pinion in two pieces on Sunday. had a new rear in it that night at 1:00 AM but then found out the transmission was broken, we later found out it had broke the input shaft
I am in the process of getting a new rear under it (all strange products) 3.0 gears. and with that I will loose the heavy steel wheels. that will be a 70 lb rotating mass reduction in weight,  I'll scale the car again after its all said and done.  I believe on pump E-85 and below 15 lbs of boost I can go to my cage limit of 8.50's
if you look on the internet at sick week and Jeff Lutz I was lined up next to him.  It had rained that morning and my rear window leaked water into the trunk.  as I did my burnout water leaked under the car, Someone said I was leaking the starter backed me up didn't see any water pulled me back in   It spun really bad. let off and it wheel hopped bad enough to break those parts and it came loose on the next run in. the middle of a big wheelie.
