Author Topic: Haskell FE rocker shaftless valvetrain  (Read 5180 times)
wsu0702
« on: April 17, 2021, 03:41:59 AM »
Set NHRA Super stock  records back in the '70s.  No more broken rocker shafts at high RPM.....
6667fan
  • Every Second Counts
Re: Haskell FE rocker shaftless valvetrain
« Reply #1 on: April 17, 2021, 07:00:06 AM »
I had some of those laying around here about ten years ago. Have you had that set long?
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
GerryP
« Reply #2 on: April 17, 2021, 08:12:02 AM »
It's amusing that guys with stud mounted rockers are spending bags of cash to convert to shaft mounts.  While we shaft mounters are looking for a stud mount solutions.  Imagine two guys standing at the speed shop counter each looking for a solution in a box.
allrightmike
« Reply #3 on: April 17, 2021, 08:18:07 AM »
   Grass is always greener?
'60 Starliner 427 4speed.
« Reply #4 on: April 17, 2021, 08:23:17 AM »
I'd much rather have a shaft mount.   All of your high end rocker systems have a common mounting base with paired rockers on little shafts.   Bulletproof.
1968galaxie
« Reply #5 on: April 17, 2021, 11:20:30 AM »
I guess no one looked at rocker arm geometry back then.
How high the rocker arm pivot is - no way to get remotely near to mid-lift geometry.(not even close)
The reason factory FE shaft failures occurred is due to lack of shaft support. Not because it was a shaft design.
Neat to see what was thought to be fantastic way back then. Just like 1/2" rod bolts. :)
Cheers
Eken1
« Reply #6 on: April 17, 2021, 02:31:35 PM »
How does the Y block rocker arm design compare to the FE in strength with two bolts per pedestal and no bolt holes in the shaft?
« Reply #7 on: April 21, 2021, 06:31:05 PM »
I looked at getting the Haskell setup back in the early 80's but i'd need pushrod oiling which my 427 block wouldn't provide. At that time John Haskell was racing a yellow and white shortened 57 Ford wagon with a High Riser!
wsu0702
« Reply #8 on: April 22, 2021, 03:07:00 PM »
It's not mine just a pic from my files.
