Author Topic: They’re Twistin, They’re Twistin, They’re Twistin the axle away  (Read 9985 times)
6667fan
  • Every Second Counts
Part of off season upgrades include some new 31 spline Moser shafts for Fairlane. I pulled the driver’s side yesterday and saw this. The passenger side appeared straight. They were out of a 68 GT 350.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
Jb427
Re: They’re Twistin, They’re Twistin, They’re Twistin the axle away
« Reply #1 on: April 11, 2021, 07:58:12 AM »
Are they 28 or 31 spline factory axles? I am still unsure if i will go 31 or 35 spline an axle braking or a tail shaft failing is like taking a can opener to even strong parts of your car if they don't put in the wall or worse ive see what happens when a tail shaft brakes on a dyno a friends bmw v10 drift car looked like a bomb exploded and another brand new build falcon first time at the drags for fun not even a really fast car broke the tail shaft and wrote the car off. Axle broke on on the falcon race car and almost took out the rear quarter that one broke at the flange but from coming off the track at high speed then slow speed bump finished it off wheel did stay under but made a mess that is for sure.
« Reply #2 on: April 11, 2021, 10:18:14 AM »
Lucky you caught it before it broke. OEM axles? 28 0r 31 spline?
6667fan
« Reply #3 on: April 11, 2021, 12:36:05 PM »
That is an OEM 31 spline axle from the aforementioned GT 350. If I was doing it from scratch I would go 35 spline. I’m working with my TrueTrac 31 spline differential so bought the 31 spline Mosers.
JB
67 Fairlane 500
482 cid 700/617
« Reply #4 on: April 11, 2021, 02:03:16 PM »
Odd, they usually twist in a linear fashion (more towards the drum side, not inside the spyders) well outside of whatever differential is used. Those wavy splines inside the diff are very odd.
Have seen my share of broken OEM's but almost always in drag racing. I wonder if  heavy track road racing, with lots of hard an/off cornering, was the culprit here.
« Last Edit: April 11, 2021, 02:07:10 PM by machoneman »
Jb427
« Reply #5 on: April 11, 2021, 07:47:46 PM »
Main thing is you caught it now before a failure on the bright side your car must be hooking up ok at the track.
Road racing almost never see them twist they brake or crack from coming off the track sideways and hitting ruts and bumps off the track.
« Reply #6 on: April 11, 2021, 09:58:45 PM »
Last axle I twisted off was coming off a light. I pulled second and it came unhooked. I was about a half mile from my intended goal, (Taking my daughter to school in the morning) and I had enough speed up that I coasted to the parking lot. I pulled it apart when the 'hook' got me home.
It looked just like your picture. I used a long piece of copper tubing with a small steel cable in the middle with a loop on the end to get the stub end out and slipped in a replacement shaft. The bone yard asked $35.00 for the replacement. :)
« Reply #7 on: April 11, 2021, 10:43:15 PM »
I'm just surprised a 68 GT350 had 31 spline axles.
427John
« Reply #8 on: April 11, 2021, 11:03:45 PM »
Yeah my 68 J-code 4 spd. mustang didn't even have a 9 inch.
« Reply #9 on: April 12, 2021, 01:31:56 AM »
All the 271 HP Fairlane & Mustang's, from at least '64, had 9" rears and top loader 4 speeds.
6667fan
« Reply #10 on: April 12, 2021, 07:59:18 AM »
A friend calls me up and asks if I want a 9” from a Mustang that he has. He had bought it out of a private boneyard for his 65 2+2. It was a later housing and of course too wide for his 65. I take a look at it and my eyes about fell out of my head when I saw it had a SPEC case.
It was dated 12/67. Supposed to be out of a 68 GT 350 carcass. Had an open 3.89 diff.
 I wanted to upgrade my Fairlane so I put the axles in my car with the new TrueTrack diff. The housing was sold and the case went to a guy with a W code Fairlane. The more serious I get about trying to get a number at track with car caused me to consider how much I should be asking of 50 plus year old factory axles.
Can that axle be straightened and used in a pedestrian manner or is it only wall art now?
JB
67 Fairlane 500
482 cid 700/617
BigBlueIron
« Reply #11 on: April 12, 2021, 10:59:32 AM »
That axle shaft is done. Not usable.
427John
« Reply #12 on: April 12, 2021, 12:06:23 PM »
Yeah but a 68 GT350 didn't have a K-code 289HP/271hp they had the J-code 302/230hp.The 69 went to the 351W.
« Last Edit: April 12, 2021, 12:08:24 PM by 427John »
gt350hr
« Reply #13 on: April 12, 2021, 12:20:39 PM »
6667 fan ,
   I can use it if you are going to toss it . Clutch hub alignment of traction lock assembly. Will pay shipping , no problem.
  Randy
« Reply #14 on: April 12, 2021, 02:48:04 PM »
Must have been a non-GT J-code?  Not an expert on 68s, but as I understand, J-code GT got 9 inch and front disks, non-GT got drums and 8 inch.
J-codes are good running stock 302s, hope to be doing one here shortly.  Last one was an overachiever with only mild changes
