Author Topic: Videos of one after it's in the car - Danny T's all-iron 461 CJ  (Read 5439 times)
« on: February 23, 2021, 03:35:49 PM »
This one was in the dyno section a long time ago, 525 HP range, 15+ inches of vacuum, pump gas, all iron, including the intake.  Painted and detailed to look like a CJ fresh off the assembly line in 1968. Only non-stock look are headers and a double pumper for a Day 2 appearance, but even then, the carb is hidden under an original ram air air cleaner.
The car is a beauty, and Danny is finishing the resto and got it fired.  This one ran really well and did everything we wanted, but the sound really is the icing on the cake.  Just right for a what a Day 2 CJ would sound like, but at 150 more HP than most saw in the day!
https://youtu.be/AJEC--DkrVw
https://youtu.be/Yh-eUhjo-S4
Enjoy!
« Last Edit: February 23, 2021, 07:02:35 PM by My427stang »
1968galaxie
Re: Videos of one after it's in the car - Danny T's all-iron 462 CJ
« Reply #1 on: February 23, 2021, 04:38:49 PM »
Well done!
Looks as good as it sounds.
Can't wait for an in-car video - melting the tires.
Henrysnephew
Re: Videos of one after it's in the car - Danny T's all-iron 461 CJ
« Reply #3 on: February 23, 2021, 08:56:02 PM »
Very nice Ross, hydraulic roller cam?  Randy M
« Reply #4 on: February 23, 2021, 09:22:28 PM »
Yes, hyd roller cam, Lykins non-adjustable roller rockers, Doug Garifos stands
427Fastback
« Reply #5 on: February 23, 2021, 10:15:56 PM »
well done and see its a 428 Coupe.
1936 Diamond T 212BD
1990 Grizzly pick-up
« Reply #6 on: February 24, 2021, 04:32:07 AM »
From the factory 4.30 4 speed CJ coupe, and he did it nice.  Great car
« Reply #7 on: February 24, 2021, 08:58:04 AM »
Looks great, will it see any dragstrip action at all? Could surprise some newer muscle cars, if it can find any traction.
« Reply #8 on: February 24, 2021, 12:31:49 PM »
It certainly is not its  primary use but I think you’ll probably see it at the FE Reunion. It’s got Caltrac bars and their mono leaf rear springs out back, should do ok compared to my tire burner lol
Twinibeam66
« Reply #9 on: February 24, 2021, 02:04:53 PM »
Sharp Mustang !!! and sounds great !  Wonder what the cam specs are ??
« Reply #10 on: February 24, 2021, 02:23:33 PM »
I used a single pattern custom hyd roller, 237 @ .050, 114 LSA Intake flowed over 300 and exhaust was very good with a properly sized primary pipe . Typically a little split on the exhaust side works better but in this case we were very fussy about making vacuum, so we tried to make the exhaust and head work well
Twinibeam66
« Reply #11 on: February 24, 2021, 02:59:16 PM »
ok thanks it sounds so good had to ask
« Reply #12 on: February 25, 2021, 12:13:31 AM »
That looks and sounds great.
