Author Topic: 66 Fairlane Reborn  (Read 96122 times)
Re: 66 Fairlane Reborn
« Reply #75 on: June 28, 2024, 01:57:53 AM »
Looking good
Jb427
« Reply #76 on: July 08, 2024, 02:08:12 AM »
Cheers Heo it is slow going but inside is almost finished.
Found a few things unique to an A/C 66 fairlane there is a brace on the drivers side that goes from the firewall down to the handbrake mounting hole a factory A/C one must be wider near the vent duct fits not too hard a fix if you can weld and bend some sheet metal other one is the ashtray must be over 1 inch shorter in an A/C car I will cut shorten and weld mine soon.
All vacuum and heater hoses are finished still waiting on compressor bracket to come back from the chrome platers before I can start fitting A/C hoses and condenser dryer
« Last Edit: July 08, 2024, 02:13:31 AM by Jb427 »
Jb427
« Reply #77 on: August 17, 2024, 01:06:11 AM »
Started to get some more work done on the fairlane's A/C system
Low mount compressor bracket needed to be changed to fit my set up and get all the belts to line up and run true but it is all done now. Next major job is remaking the radiator fan shroud I need to change my fan from left had side fan mounted top and right hand side fan mounted low to left low and right high.
I will add if anyone was thinking of fitting one of these low mount brackets I would say get one that is not welded I bought 2. One welded and one not welded the welded bracket would not work for my set up.
Here are some photos of the set up
« Last Edit: August 17, 2024, 01:31:56 AM by Jb427 »
« Reply #78 on: August 17, 2024, 08:44:28 PM »
Nice.
6667fan
  • Every Second Counts
« Reply #79 on: August 18, 2024, 12:32:08 PM »
Sanden unit?
Ash trays different, yes. Perhaps due to proximity of original center vent duct work. Looks like some clean work there.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
Jb427
« Reply #80 on: August 18, 2024, 05:37:54 PM »
Sanden unit?
Sanden 508
The ash tray hits the demister-floor vent
I will try to do a list once every thing is finished of parts I think people forget about but are a must to grab off a car if you found a wreck with A/C and wanted to fit it into a non A/C car.
Like the ash tray, A/C blower motor switch, dash to hand brake brace, A/C blower motor switch wiring harness. To name some of the main items that will save you time and money.
6667fan
« Reply #81 on: August 18, 2024, 06:31:34 PM »
That’s a good idea. There is probably something like that on the FCA site.
JB
67 Fairlane 500
482 cid 700/617
TurboChris
« Reply #82 on: November 08, 2024, 12:00:09 AM »
When you say "these" are you referring to the ones offered by Tyler Blankenship? I have one and am hoping to fit it next year.
Jb427
« Reply #83 on: November 08, 2024, 07:21:55 AM »
Yes I do mean Tyler's bracket.
My set up was is very unique and I was very room limited if I had more room my install would not of been as much work. I have had my radiator fan shroud finished for a few weeks now it was a big job. Here are some photos of new fan shroud it pulls apart now so it can be removed with-out pulling off the water pump that is how little room I have.
Next big job is relocating engine and trans coolers and mounting condenser.
TurboChris
« Reply #84 on: November 08, 2024, 01:36:18 PM »
Great photo's. Thanks for that! Really makes me look forward to doing mine.
Jb427
« Reply #85 on: November 08, 2024, 02:19:23 PM »
Thanks Chris I don't think you will have too much problems.
Because I was so tight for forward room I had to run my compressor belt on the front pulley grove on the compressor. My compressor is flat on the out side bracket and I had to move the rear bracket back.
All the the photos I have seen they space the compressor forward like Tyler said they need to be custom fit that is why after fitting one I would suggest people to get the non welded bracket to give you the most options to custom fit it to your car/truck.
TurboChris
« Reply #86 on: November 08, 2024, 02:41:59 PM »
Thanks yeah, I def have more room to work with than you.
Jb427
« Reply #87 on: September 01, 2025, 12:18:27 AM »
small update got my new engine and transmission coolers mounted up fans wired and lines plumbed I also have dummy fitted the A/C condenser now that I have all the distances set I will remake some better mounts.
« Last Edit: September 01, 2025, 12:24:23 AM by Jb427 »
