Author Topic: 66 Fairlane Reborn  (Read 96130 times)
Jb427
Re: 66 Fairlane Reborn
« Reply #45 on: May 12, 2021, 12:07:21 PM »
Jb, if I understand you correctly you still have a clearance problem between rad and wp pulley?
I have the same Derale fan set up in my mustang. I was able to cut about a half inch out of the fan housing that butts to the rad and gain clearance. But you have to be careful not to cut off so much that the center of the fan motor contacts the rad fins. Then you have to weld new brackets on.
Hope I understood you. You guys talk funny down there. ;D
With my 390 with stock engine mounts i had about 1/4 inch clearance between the pulley bolts and fans just enough room that i could install/remove a fan belt. My fan shroud is cut down too just like you did around 1/2 inch i cut it down as tight as i could go with out the fans hitting the radiator. I think the engine mounts are the big change cause they are fabricated they need some tweaking i have not looked at slotting any holes yet in the engine mounts but i will look and try some things over the weekend I was hoping i could make it better then before when i wanted to remove the radiator i use to have to remove the water pump first. If i can make the bypass work with out it being a pain to install i will use it but when i get my new water pump i was going to delete the bypass and mod the thermostat with some holes around the outside just to make it better to fit.
Yes we do  ;D and we do the best burnouts in the world  ;) https://www.youtube.com/watch?v=GyzFhUSIpaQ
« Last Edit: May 12, 2021, 12:12:57 PM by Jb427 »
« Reply #46 on: May 12, 2021, 12:27:19 PM »
LOL
I’ll give that to ya.
Admire the attitudes and cars down there.
Jb427
« Reply #47 on: May 13, 2021, 09:26:42 AM »
Had a good Win today  ;) moved the engine mount spacers around and remade radiator mounts ended up with more room like i wanted about 1/2 inch between the pulley face and fan's.
66FAIRLANE
  • Andy
« Reply #48 on: May 13, 2021, 08:15:27 PM »
Gotta celebrate the wins. Good stuff!
Jb427
« Reply #49 on: May 14, 2021, 04:45:14 AM »
Sure is good to have a win
If all goes well finishing off the last few bits of wiring really just fuel pump and fuel pump safety switch and the ice ignition i will try to get it running next week. New water pump is on its way ill get some fresh pic's next week.
Jb427
« Reply #50 on: May 29, 2021, 01:09:16 AM »
Good news Engine got it's first start up today all went well so far. Needs a more camshaft :P still waiting on throwout bearing before i can do any more sadly.
66FAIRLANE
  • Andy
« Reply #51 on: May 29, 2021, 01:47:05 AM »
How much cam ya got now?
Jb427
« Reply #52 on: May 29, 2021, 02:02:45 AM »
258 264 @50 108 696 lift i have already emailed Brent ill have a chat to him about a spicy stick.
Jb427
« Reply #53 on: July 08, 2021, 04:39:34 PM »
It took some time but gearbox and hydraulic throwout bearing is finished the strange 35 spline truetrack 3rd member and 35 spline mark williams axles are geting done now. Still working on a custom hurst shifter handle sadly i wont have my bucket seats done in time for my goal of all ford day in 2 weeks. I hope to have the car driving by then here are some pic's of the mods done to throw out bearing lines so gearbox can be removed and installed with out pulling scatter shield.
« Last Edit: July 08, 2021, 04:41:40 PM by Jb427 »
« Reply #54 on: July 08, 2021, 06:32:43 PM »
That aint a little cam - it just idles nice for a street racer.  I've had a couple guys north of 650HP and into the low tens/high nines on a similar stick.
Jb427
« Reply #55 on: July 09, 2021, 06:46:20 AM »
Don't get me wrong Barry it will be a ripper
Jb427
« Reply #56 on: September 08, 2021, 11:57:30 AM »
Car is done and driving after a long wait for axles I have a few small things to fix the new engine has lowered the car about half an inch it needs to come up and inch at the front.
fresh pic.
66FAIRLANE
  • Andy
« Reply #57 on: September 08, 2021, 07:01:32 PM »
 :D Looking great! There's always something to do. I'm still doing a bit here and a bit there but driving it in the meantime. How is it driving, I bet your loving it?
Jb427
« Reply #58 on: September 09, 2021, 01:50:20 AM »
It drive's good have not gone far yet need to adjust a few things first clutch is pain it comes off the floor 3 inches before it starts to grab i will talk to mal woods about that see if there is anything that can be done or if i just need to put a stop on it. Scatter shield is 40mm off the ground need to fix those before running it in. Set of springs will go in it this weekend going to buy a set of the coilover's soon.
Jb427
« Reply #59 on: November 21, 2023, 10:58:10 PM »
Update post
Car has had a few changes I have over 5000miles on the engine now and it has been flawless swapping from the 4 speed to c6 auto 3500 converter works very well.
New Seat covers and door trims showed up back in September after almost a 2 year wait still needs to have the console covered yet.
Fitted Aldan coilovers in the front they are a great kit well worth the money still looking at adding a gearvendors OD and maybe upgrading to wilwood brakes all round.
Here are some fresh photos
« Last Edit: November 21, 2023, 11:08:35 PM by Jb427 »
