Author Topic: Trickflow Tunnel wedge intake  (Read 34449 times)
Jb427
Re: Trickflow Tunnel wedge intake
« Reply #60 on: July 26, 2024, 02:25:26 PM »
My combo is 482 ported bbm's heads solid roller and I run a 1 inch spacers on top of mine
Gregwill16
« Reply #61 on: July 26, 2024, 08:37:52 PM »
Thanks guys. I am surprised there aren’t more examples. Part of me thinks since TFS was aiming at the more normal size FE that it may not be bad. But with no examples I am starting to lean towards trying to find or trade the TW for a BT instead. It is hard to beat the look of a TW but don’t want a lot of fuss.
Jb427
« Reply #62 on: July 26, 2024, 11:41:40 PM »
What is the engine combo you plan to use?
« Reply #63 on: July 27, 2024, 06:50:12 AM »
I haven't seen any tunnel wedge or single plane FE behave badly on the street.  If you have 427 cid or more and want dual quad, I'd go for it.  Cam it appropriately for use and enjoy it
Jb427
« Reply #64 on: July 27, 2024, 07:25:06 AM »
I agree with My427stang
Gregwill16
« Reply #65 on: July 27, 2024, 07:32:22 AM »
It is a 461 with TFS heads. I agree, I think it will be okay, but was hoping to get some examples for reference.
On the cam, Ross I’ll be reaching out to you and Brent for some advice on a cam I have and whether I should use it or go HR.
MeanGene
« Reply #66 on: July 27, 2024, 08:45:16 AM »
Mine is a Dove that came off a V-drive boat, has 2" spacers under 660's. Guy said it ran great and very fast, just hard to keep gas in it- that loud pedal, y'know
6667fan
  • Every Second Counts
« Reply #67 on: July 30, 2024, 10:14:03 AM »
The original FOMOCO design may not have been engineered for street use but it’s no problem running one. Most of the builds on here,(and yours), have so much “nut” down low it won’t matter that it’s a single plane.
I’m assuming that it does not have the mongo airflow of the larger BBM piece
« Last Edit: July 30, 2024, 10:23:15 AM by 6667fan »
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
MeanGene
« Reply #68 on: July 30, 2024, 11:46:32 AM »
It is my understanding that the Dove like mine is also larger inside than the original? Of course I could go look it up in Jay's book, but maybe others like Joe Craine can confirm?
« Reply #69 on: July 30, 2024, 11:55:11 AM »
Yes, Jay tested the manifolds for total volume,  the original Ford Tunnel Wedge was 4000 cc's, the Dove Tunnel Wedge was 4125 cc's. Jay's book was published before either the BBM or Trick Flow Tunnel Wedge were available,  I've asked a couple times on the forum here in the past if someone could take the volume measurements on those intakes for us, to have some real data, but so far I haven't seen anyone report that info.
