Author Topic: Head gasket for blower motor?  (Read 3806 times)
« on: September 30, 2020, 10:40:39 AM »
Hey Jay, or anybody,  what type of head gaskets do you use on your blower motors?  Jay, I mentioned you specifically because you have the centrifugally blown FE.
What would you use on an iron factory block with aluminum heads?  Low boost like 8-10 pounds.  Centrifugal blower.
Thanks,
paulie
Re: Head gasket for blower motor?
« Reply #1 on: September 30, 2020, 09:20:57 PM »
Use a Cometic MLS (Multi Layer Steel) gasket, Paulie, they can handle the heat and cylinder pressure of a blown motor - Jay
« Reply #2 on: October 01, 2020, 06:06:06 AM »
Thanks!
« Reply #3 on: October 01, 2020, 08:08:34 AM »
Most certainly Cometic.
I also like putting Inconel exhaust valves in as an added defense.
« Reply #4 on: October 01, 2020, 09:45:20 AM »
Thanks Brent!
« Reply #5 on: October 01, 2020, 04:09:50 PM »
Cometics even on my lil 390 with 5# of boost.  Granted it doesn't see racing pressures, but after 20 yrs I haven't touched it.
Faron
« Reply #6 on: October 02, 2020, 10:01:32 AM »
Cometics are great , but I use Felpro 1020's less prep less cost and I've run 12lbs of boost , never lost a gasket
