Author Topic: 360 horse 352  (Read 70523 times)
WerbyFord
Re: 360 horse 352
« Reply #90 on: October 04, 2020, 08:16:21 AM »
What was Holley's biggest carb in 1960?
Near as I can figure:
390cfm = 1957 312/245
450cfm = 1958 383/312
550cfm = 1958 383/330
600cfm = 1958 430/360
So Ford could have gone up to 600cfm for the 352/360hp.
Strangely, the Dec 1960 article on the new 390/375 (600cfm) says NOT to backfit the big 600cfm carb to the 352/360hp. Both seem small to me.
715cfm = 1963 427/410
780cfm = 1965 427/410MR
850cfm = 1967 427/L88 maybe
950cfm = 1968 427TP 3bbl maybe
1050cfm = 1969 429 Boss Dominator maybe
Just guessing on those last few.
allrightmike
Re: 360 horse 352
« Reply #91 on: October 04, 2020, 09:01:19 AM »
Could be  Ford knew that the 360 HP rods & valve springs wouldn't play nice with a larger carb.
'60 Starliner 427 4speed.
wayne
Re: 360 horse 352
« Reply #92 on: October 04, 2020, 10:43:59 AM »
May be the pistons are 428 industrial.
Re: 360 horse 352
« Reply #93 on: October 04, 2020, 05:04:39 PM »
Werby, your list misses a few factory ringers like the -DT and -BF List 2953
I agree tho, if given the task of carbureting the 352HP, I’d be starting with the 715.
Royce
Re: 360 horse 352
« Reply #94 on: October 04, 2020, 06:08:50 PM »
Isn't there a big Autolite in there for the 58 430.. Did the 60 430 use an AFB?
1961 Starliner 390/375 clone
1965 GT40 tribute w/FE
1992 BMW V-12 5.0
2001 Lincoln 5.4 4 cam
2000 Jaguar XK8 (Ford V8)
Re: 360 horse 352
« Reply #95 on: October 04, 2020, 08:32:30 PM »
If memory serves me correct, the couple of intake I have looked at, the holes were smaller than the butterflies of the 600 cfm Holleys, and would be a big hinderance to flow and create turbulence.  The throttle blades would not open properly?  I have a very old Holley here that I will look at tomorrow and see if I can identify the year/vehicle/throttle blades sizes.  Joe-JDC
allrightmike
Re: 360 horse 352
« Reply #96 on: October 05, 2020, 07:10:12 AM »
I am told that the largest 4100 Autolite carb. came on the high torque '58 Merc. 383 at 669 cfb with a 1.10 venturi.
Re: 360 horse 352
« Reply #97 on: October 05, 2020, 11:03:16 AM »
They made the the 4100 as large as 674 cfm and a 1.19 venturi.
http://mustangtek.com/carburetors/FordCarburetors.htm
From my 1960 Ford Shop Manual, it looks like all the 300 hp, 4v's, that year were 4100's. My manual doesn't have the 360 hp engine in it.
RJP
Re: 360 horse 352
« Reply #98 on: October 05, 2020, 12:04:14 PM »
With early iron intakes the throttle bores are indeed smaller than carb's throttle plates and most likely create transition turbulence. Early intakes [EDC?] also have what appears to be a pretty swoopy looking runner system with a plenum [and runners] similar to the later high performance aluminum manifolds. In the early 70s with one of these manifolds I scribed and bored the 4 throttle bores out to 2.125" each on a radial drill press and ran a 715 Holley. The setup worked great, no interference with throttle blades, no bore restrictions and the manifold/carb setup would pull hard to about 5400-5500 on a mildly built 390 with a 406 solid lifter cam. Only drawback to that manifold was the weight. Performance was on par with most FoMoCo aluminum manifolds I've used.
Re: 360 horse 352
« Reply #99 on: October 05, 2020, 02:20:48 PM »
The Holley I have is a R-4548, which is listed as '61-67 352-428 carb in the Holley reference manual.  Joe-JDC
RJP
Re: 360 horse 352
« Reply #100 on: October 05, 2020, 03:37:56 PM »
My old Colt Industries book shows that carb as a service replacement for 302-390-428 and 429 and judging by pri. jetting  [22R-40-57] and a #30 sec. plate with .064" main/.029" idle] it would seem to be about a 450 cfm carb at best.
pbf777
Re: 360 horse 352
« Reply #101 on: October 05, 2020, 07:57:35 PM »
     Not that I'm aware of; but I am aware of the Holley's appearing on the '58 Mercury's with the M.E.L. 383's, and 430's (LIST: 1405A & 1740A, Ford #EDJ-9510-A & #5750897) but except for some early photos of say perhaps pre-production '60 430 installations they seem to have all received the Carter's?  There is a Holley "List" number 1850A and a FOMOCO stamped number Holley, which based on literature supposedly was intended  for the 430 in '59 & '60, and actually quite commonly encountered in the used market, but I haven't found them on any "proper" 430 M.E.L. cars?                 ???
    But maybe I just didn't get the memo?               ::)
     Scott.
RJP
Re: 360 horse 352
« Reply #102 on: October 06, 2020, 11:05:22 AM »
I have a 1850 with the 6 digit FoMoCo part number somewhere. When I get into the shop today or tomorrow I'll find it and post the actual numbers. The Colt book has this as a 1958-61LIncoln 430, 1958-59 Merc. 430 and 59-61 T-bird 430.
Re: 360 horse 352
« Reply #103 on: October 06, 2020, 11:09:53 AM »
If it’s a List 1850 it’s probably this one with the 7 digit “boxcar” number.
pbf777
Re: 360 horse 352
« Reply #104 on: October 06, 2020, 04:43:03 PM »
    Yep, #5752426, that's the number I didn't remember.             :)
    Scott.
