Author Topic: Speedmaster  (Read 7641 times)
475fetoploader
Speedmaster
« on: August 05, 2020, 10:18:58 AM »
Ok so Jegs advertises Speedmaster 4.375 forged cranks, drop shipped starting 8-14-20. Has anyone heard if they’re any good, and really available?
1967  519 c.i.  TKX 5 speed
Re: Speedmaster
« Reply #1 on: August 05, 2020, 10:25:28 AM »
I know of literally zero Speedmaster products that I would trust, especially ones that have to rotate at thousands of revolutions per minute while trying to handle massive forces acting upon it.
Re: Speedmaster
« Reply #2 on: August 05, 2020, 10:46:18 AM »
+1 on what Brent said on Speedmaster quality (or lack thereof).  Also, it wouldn't surprise me one bit if that date came and went Summit's site, and a couple days after that date it was pushed out by another month.  That same thing happened with my PAC valve springs that I tried to order through Summit.  Pushed out a month four times before I finally cancelled the Summit order and got them from a different distributor.
pbf777
Re: Speedmaster
« Reply #3 on: August 05, 2020, 11:05:19 AM »
     +1             ;)
     I wish the American public would stop with this determination, or maybe it's a syndrome, to purchase the CHEAPEST-SHYT-POSSIBLE!             :o
     Scott
HTRDHARLEY
Re: Speedmaster
« Reply #4 on: August 05, 2020, 11:17:38 AM »
Anyway we can do a group order for 4.375 cranks through Callies or another quality American manufacturer?
475fetoploader
Re: Speedmaster
« Reply #5 on: August 05, 2020, 01:09:05 PM »
4.250 it is! Thanks fellas.
Re: Speedmaster
« Reply #6 on: August 05, 2020, 01:13:22 PM »
I can do quantity order of custom Scat forged cranks in a 4.375" stroke, 2.200" rod journal.  Would probably take a quantity of 5-10 to get the price "do-able" and even then they'd be somewhere around the $1800-1900 range.
475fetoploader
Re: Speedmaster
« Reply #7 on: August 05, 2020, 02:02:25 PM »
I have too many projects like normal. Ok 428 block Edelbrock heads basically out of the box. It’s going into a 4x4 pickup. I have a mental block about cast cranks. What kind of limits does a 4.250 crank have, rpm/h.p. Let’s assume Molnar rod, diamond piston. Flat tappet cam.
Re: Speedmaster
« Reply #8 on: August 05, 2020, 02:09:30 PM »
You'd have no problem with a cast Scat crank in that application, plus a couple hundred horsepower.
HTRDHARLEY
Re: Speedmaster
« Reply #9 on: August 05, 2020, 03:13:27 PM »
You can put me down for two.
Joey120373
Re: Speedmaster
« Reply #10 on: August 05, 2020, 04:45:31 PM »
And you can put me down for 1.
I am curious, as these are custom forging, would they all have to be the same, or could we ask for variances.
For instance, a 2.1 rod journal and longer stroke? I asked about this I. Another thread, still not sure it’s worth messing with but figured I would ask anyway.
I am assuming that these are all cut on CNC machines so what would it matter to change it up a bit..
Re: Speedmaster
« Reply #11 on: August 05, 2020, 05:45:45 PM »
Probably so.  If I can get a couple more guys interested, I'll see what my Scat rep says.
Joey120373
Re: Speedmaster
« Reply #12 on: August 05, 2020, 07:00:53 PM »
That would be awesome. Thanks Brent.
HTRDHARLEY
Re: Speedmaster
« Reply #13 on: August 06, 2020, 06:35:07 AM »
Great, Thank you.
Lars 704-363-9913
HTRDHARLEY
Re: Speedmaster
« Reply #14 on: August 11, 2020, 02:08:26 PM »
Anyone else interested?
