Author Topic: Welding a 427 block  (Read 11499 times)
chilly460
Welding a 427 block
« on: August 02, 2020, 06:08:59 PM »
Snagged a standard bore 427 marine block at Carlisle with a cracked water jacket, and wanted to get an opinion on the best way to fix.  Also, any known good cast iron welders in the Mid Atlantic region, let me know as I can travel a bit to get the block fixed.
Can't read the date code on this one, first number is mangled.  I know sometimes they can be dated depending on which foundry location they came from, this is a DIF block.  Looks to be drilled for hydraulics but I haven't pulled the plugs for the galley crossover to see if they're plugged.
Pretty excited to get a 427 block and had to take a bit of a leap a faith to grab it.
Chrisss31
Re: Welding a 427 block
« Reply #1 on: August 02, 2020, 06:28:32 PM »
You can look into stitching it back together too.  I've seen this done before it's pretty neat.  There are a few places that do it, below is just an example.
https://www.metalockengineering.com/en/typical-repairs/metal-stitching/
Chrisss31
« Reply #2 on: August 02, 2020, 06:39:31 PM »
chilly460
« Reply #3 on: August 02, 2020, 06:41:22 PM »
Thought about the stitch locks too, but wasn’t sure if they’d hold water, I’ll look into it
« Reply #4 on: August 02, 2020, 06:46:20 PM »
The date code under the oil filter adapter pad looks to have the two dots under the leading year digit. Those two dots under the year started around 1969. Just going by memory, but I don’t think I’ve seen any FE blocks with the two dots in 1968. Your block doesn’t appear to the have the external “ribs” on the outside of the block, best we’ve figured out so far the “ribs” started near the beginning of the 1971 calendar year in DIF cast blocks. There’s a thread going elsewhere on the forum here about the “ribs”. So my guess is it was cast in 1969-1970 calendar year.
wayne
« Reply #5 on: August 02, 2020, 07:26:32 PM »
Find some one who can check it over good before you put much money in it i  had two Fe broke like that a 427 and a 428.After fixing the crack like yours they both leaked inside some where.I am not trying to rain on your parade i hope yours is ok.
475fetoploader
« Reply #6 on: August 02, 2020, 07:39:35 PM »
Worked at a Diesel machine shop, we called that pinning. Fixed lots of big, odd diesel blocks with huge windows in them that way. We had good success with no external leaks. Very time consuming, but none of the problems associated with welding existed.
1967  519 c.i.  TKX 5 speed
« Reply #7 on: August 02, 2020, 07:58:28 PM »
I'd also recommend pinning, you can do it yourself.  Not that hard, I've fixed SOHC heads with it.  I use the products from the link below:
http://www.locknstitch.com/index.html
« Reply #8 on: August 02, 2020, 10:22:41 PM »
For welding, the best, bar none, is Chris Razor, Hi Tek Welding, 734 414 1994, in Plymouth, Michigan. When he welds cast iron, he uses a system developed for repairing the giant ladles used in steel-making. Last I knew, he was a co-owner of the necessary equipment along with Jack Roush, who is his partner in the stuff. Chris does their specialty work.
Back in 1990, FoMoCo built a running prototype/show car and called it the GT 90. It was powered by a V-12 version of the four-cam V-8. The crank and cams were billets made for the purpose, but the block and heads were made by lopping the front two cylinders off one set of castings and the back two off another set. Chris Razor welded the two sets of six together  to make a 12 cylinder running engine. The engine had four turbos on it.
I have seen Chris run a perfect bead on the sharp edge of a razor blade.
« Last Edit: August 02, 2020, 10:51:54 PM by cammerfe »
« Reply #9 on: August 03, 2020, 04:51:15 AM »
Chris, my local guy can handle that pretty easily.   Text me if you want his number.
jimeast
« Reply #10 on: August 03, 2020, 07:01:44 AM »
I've used Midwest Cylinder Repair to weld up an SOHC head that was too far gone to stitch.  Probably 12 yrs.  They were recommended on the FE forum.  Did a great job.  They should be able to do a block since the SOHC head is about as big as a block :)
It was a proper repair, first they heat the part in an oven to a very high (red) temp and then weld in or melt in cast iron material.  I think their main business is diesel and farm equipment cylinder head repair
Some of the guys on this forum or the FE forum have used them.  Maybe you can get a more recent review.
With this block after the repair (regardless on how it's fixed) you should expect a full machining regimen
428kidd
« Reply #11 on: August 03, 2020, 07:25:55 AM »
I'm going to second Brent's local guy I've used him a lot the last couple years!! Rays does great work and pressure tests them before they get a clean bill of health!
chilly460
« Reply #12 on: August 03, 2020, 09:27:16 AM »
Appreciate all the feedback, will sort through responses and follow up.  It'll probably come down to proximity more than anything as it's obviously going to be $$ to ship a block.
RustyCrankshaft
« Reply #13 on: August 03, 2020, 09:02:27 PM »
Stitching works and if done well is water tight and you can't tell where the repair has been done. I've done quite a few big diesel block repairs.
Also stitched dozen of 4-71 Detroit blocks! EPA gave a tug boat outfit a grant to repower a bunch of stuff with newer engines. They started with all the auxiliary engines and I had a friend who works for them and got hired part time and worked on the project on weekends. The grant required that the old engines be destroyed. Hole saw in the shirt between mainwebs is a destroyed block! Kept all the knocks, paid the tug company the scrape value and took home a couple dozen nice gensets. Stichted the plugs back in and a little paint and good as new.
C6AE
« Reply #14 on: August 04, 2020, 01:11:33 AM »
I have pinned a few blocks and many heads over the years. If there was metal missing I would head for a junkyard and pick another block to cut a piece from.  Not always the same engine even! There is one B-20 Datsun with a chunk of sbc pinned into it!  Fitting in a slightly larger piece made for a very good repair.
