Author Topic: 48 rte or re behind a FE  (Read 8070 times)
gregaba
« on: March 10, 2020, 06:39:02 PM »
Was at a friends shop today looking at OD transmissions.
While comparing tranny size he suggested I use a Dodge 48 rte or re. The were installed behind the Viper truck so should hold the power of the Fe good.
I really liked the size of these, about the same size as a C-4. He had 2 of them out and 1 was for a 4x4 and the other for a RWD.
I would have to build my own crank and bell houseing adapter and figure how to mount a starter as I could not find an adapter for that combination with a quick search.
Any thought's of this tranny and possible adaption?
Greg
Re: 48 rte or re behind a FE
« Reply #1 on: March 10, 2020, 09:02:54 PM »
I thought those SRT10 trucks used a t56?
gregaba
« Reply #2 on: March 11, 2020, 09:46:02 AM »
Thats what I all ways thought to, but I don't pay much attention to Dodge product's.
My friend races Diesels and does a lot of tranny work and he has been known to pull my leg sometimes.
I will check his claims out next time I drop by the local Dodge dealer and see what they say.
If it will handle the power then it is just a matter of building an adapter set up for it.
I really liked the small size of it for an OD, but if it won't hold up then I will look else where.
Greg
« Reply #3 on: March 11, 2020, 09:53:35 AM »
it's a good transmission based on a 727 ,the RH version (pre 2002) is a mechanical 3 speed and a add on electronic 4th and lock up lots of upgrades you can do too
« Last Edit: March 11, 2020, 09:59:12 AM by e philpott »
gregaba
« Reply #4 on: March 11, 2020, 11:00:22 AM »
Good to know.
 I know nothing about this tranny and plan to do a little research this evening when I can get the time.
All info is appreciated.
Greg
hwoods
« Reply #5 on: March 11, 2020, 04:58:37 PM »
Lenco making a 6  speed ST 1200 street trans now.  supposed to be good for 1200 HP.  anybody got good deals with Lenco?
gregaba
« Reply #6 on: March 11, 2020, 05:30:00 PM »
Lencos are great tranny's but a bit expensive. $6200.00 is a little out of my budget range.
If i was still racing I would consider one as we used to run them in our Pro Stock cars.
I like Lenco's and Jerico's both but won't need that much of a transmission I hope.
Greg
gdaddy01
« Reply #7 on: March 11, 2020, 07:19:27 PM »
you don't want 1200 horsepower ?
gregaba
« Reply #8 on: March 11, 2020, 07:23:54 PM »
If I had 1200 horsepower I would have to sell some of it.
Greg
« Reply #9 on: March 12, 2020, 09:23:04 AM »
The RE version is full electronic and still based on a 727 but with a electronic governor and shift solenoids so it would for sure need a computer to operate and to be able to adjust shift points and lock-up ect .
 RH is the hydraulic version but would need something electronic to control 4th and lock-up TCC along with a TV cable ( throttle Valve ) or TV Rod hooked up unless you went full manual valve body
I would say the 727 is closer to a C6 with a smaller Bell and the C4 is more like the 904 version of the 727 but it's been years since I've overhauled any 3 or 4 speed Mopars
gregaba
« Reply #10 on: March 12, 2020, 11:26:49 AM »
Thanks for the reply.
 I still havn't had time to research this. I am not to worried about the electronics as I can take care of that.
When looking at the tranny I was just surprised at how small it was compared to other overdrive's, It was still in the truck on the lift but looked a lot smaller then a 727 or C6.
It is just an ideal as I am still considering a TKO 600 5 speed but am comparing cost and can go either way. Might be better to go with a standard as I will be using the C8AX-6250-D cam.
Greg
1967 XR7 GT
« Reply #11 on: March 19, 2020, 02:47:45 AM »
Here are some tranny options, I was planning to upgrade my C6 at some point after I get it running and will probably go with one of these options:
4R70W Transmission is Done
6R80 Transmission
Transmission Gearing Ratios
Richard
FirstEliminator
« Reply #12 on: March 19, 2020, 12:41:17 PM »
ephilpott is correct on the Chrysler trans. If you are going to need an adaptor plate and a computer to run it, the Chrysler trans wouldn't be my first choice.  I'd go with a 4R70w. Or, the 6R80 sounds intriguing.  My question with the 6 speeds (whether it is from GM, Chrysler or Ford) is they are all clutch to clutch shifting that takes a lot of programming including engine management to get the proper shift over lap. US Shift has a TCM to do this and claim they have a good algorithm to make it work.  I haven't personally felt the shift quality, though I think I'd take the chance on installing a 6R80 if I were to replace the C-6 in my wagon.
Mark
Berkshire Transmissions
North Adams, Massachusetts
70 Cougar XR-7 460 C-6
69 Cougar SS 351w AOD
69 Cougar XR-7 390 C-6
68 Monterey 390 C-6
68 Monterey conv 390 C-6
58 Monterey 383 Merc-O
58 Parklane 430 MultiDrive
68 Colony Park 428 C-6
68 Colony Park 390 C-6
I don't feel like a hoarder.
hwoods
« Reply #13 on: March 19, 2020, 01:01:44 PM »
whatabout adding a GearVendors Overdrive?
FirstEliminator
« Reply #14 on: March 19, 2020, 01:31:07 PM »
Gear Vendors helps a little. It only does half of what an OD trans does.
Mark
68 Monterey 390 C-6
