Author Topic: sub frame connectors 1964 Fairlane  (Read 3691 times)
hwoods
« on: January 27, 2020, 10:47:35 PM »
anyone made their own sub frame connectors for a 1964 Fairlane?  I have seen pics of Crites and think I want something more substantial.   Thanks
Re: sub frame connectors 1964 Fairlane
« Reply #1 on: January 28, 2020, 12:02:24 PM »
Not familiar with the underside of a 64, but I used 2x2 14 gauge tube with some 2x2 angle as needed at the ends to attach to the body/floor.
66FAIRLANE
  • Andy
« Reply #2 on: January 28, 2020, 07:37:04 PM »
I'm not sure what a 64 looks like either but you can see mine for a 66 here if it helps.
http://fepower.net/simplemachinesforum/index.php?topic=7720.0
hwoods
« Reply #3 on: January 28, 2020, 08:03:26 PM »
Thanks
gregaba
« Reply #4 on: January 29, 2020, 10:52:38 AM »
I built my own for my 71 Ranchero.
Easy upgrade with 2 inch square tubing.
All you need is a measuring tape a cut off saw, grinder and a mig welder.
Greg
« Reply #5 on: January 31, 2020, 02:58:45 PM »
They don't need to be "substantial". I used 16 ga 2x2" tubing which is as thick as anything it's welded to. No need to add extra weight, you aren't building a bridge. They pass through a 2" wide slit in the rear footwells and  are flush with the bottom of the floor there and leave a gap under the seat.
hwoods
« Reply #6 on: January 31, 2020, 03:34:11 PM »
Thanks for All the feedback. I appreciate it
