Author Topic: Mopar 4.625 stroker crank offset !!!  (Read 7318 times)
winr1
« on: August 30, 2019, 10:51:00 PM »
Does an FE 4.5 look as such ??
Ricky.
plovett
Re: Mopar 4.625 stroker crank offset !!!
« Reply #1 on: September 01, 2019, 01:00:08 PM »
Are you asking about how far the crank and rod journals are offset?  The lack of overlap?
winr1
« Reply #2 on: September 02, 2019, 01:41:04 PM »
Yes, the overlap :-)
Trying to find a pic of an FE long stroke crank
Ricky.
plovett
« Reply #3 on: September 02, 2019, 06:00:30 PM »
This has more inputs than you need, but it works.
http://www.wallaceracing.com/crank-journal-overlap.php
« Reply #4 on: September 02, 2019, 07:52:11 PM »
Ricky, here is the longest stroke FE crank you are EVER going to see LOL!  4.750" stroke, stock main bearing size, 2.100" rod bearing size.
« Reply #5 on: September 03, 2019, 01:59:54 AM »
Mr. Blutarski, that overlap looks to be ZERO-POINT-ZERO on the big FE crank :D
« Reply #6 on: September 03, 2019, 07:54:33 AM »
Overlap is for cams LOL ;D
« Reply #7 on: September 03, 2019, 10:03:25 AM »
That crank can reach out and touch someone.   ;D
winr1
« Reply #8 on: September 03, 2019, 02:43:40 PM »
Wow !!   :D
Thanks Paulie
Thanks for pic Jay
Ricky.
« Reply #9 on: September 03, 2019, 11:54:00 PM »
Someone is making a 390 into a 490.
winr1
« Reply #10 on: September 04, 2019, 10:52:08 PM »
Can I install a 4.5 or 4.75 crank in my 390 block ??
An if so, a 4.09 piston would need to be custom made .. correct ??
Any vendors that can put a kit together as such and a rough cost ??
Mike Gaffney always told me to go big or go Home :-)
Ricky.
« Reply #11 on: September 04, 2019, 11:15:03 PM »
Going over 4.375" stroke in a wedge FE means you will likely run into problems with the shoulders of the rods hitting the cam lobes.  4.500" stroke can be done but some grinding or clearancing of the rod shoulders will be required.  The only reason I can use the 4.750" crank is that the engine is an SOHC.  No cam lobes to hit.
winr1
« Reply #12 on: September 04, 2019, 11:32:38 PM »
Ahhhh, thanks Jay :-)
EDIT: do rods with cap screws have more cam clearance than rods with bolts an nuts ??
I do appreciate all the answers an help to the questions I have asked here
Soon house/garage/yard will be finished an I can finally get to my 65 F100
Ricky.
« Last Edit: September 04, 2019, 11:40:07 PM by winr1 »
Bolted to Floor
« Reply #13 on: September 06, 2019, 10:55:20 PM »
Looks like happy days are coming for ya Ricky.
winr1
« Reply #14 on: September 07, 2019, 03:44:47 AM »
Aye, house finally leveled, roofers supposed to be here Monday
Then half of concrete driveway replaced, 4 piers on rear of garage, siding an paint
A bit of landscaping.... HOA will be off my but ..lol .... lookin for an acre or so with shop
And no HOA !!!! ......
Ricky.
