Author Topic: Mopar 4.625 stroker crank offset !!!  (Read 7323 times)
Bolted to Floor
Re: Mopar 4.625 stroker crank offset !!!
« Reply #15 on: September 07, 2019, 10:27:25 AM »
 The neighborhood Gestapo, gotta love-em!!
Good luck on the acre and shop.
« Reply #16 on: September 07, 2019, 11:31:11 AM »
I wonder if Jay has considered a flat-plane stroker crank? The vid below is long but it well explains the benefits and detriments of a flat plane crank. Seeing the huge FE stroker crank, I wonder how much lighter it would be as a flat crank. Given the benefits of the SOHC heads and high rpm potential, I wonder how much more hp could be achieved?
 https://www.youtube.com/watch?v=rVG6TPNcaDY
« Last Edit: September 09, 2019, 01:21:36 PM by machoneman »
« Reply #17 on: September 07, 2019, 01:56:45 PM »
I wonder if Jay has considered a flat-plane striker crank? The vid below is long but it well explains the benefits and detriments of a flat plane crank. Seeing the huge FE stroker crank, I wonder how much lighter it would be as a flat crank. Given the benefits of the SOHC heads and high rpm potential, I wonder how much more hp could be achieved?
Interesting, but flat plane 90 degree V-8's trade a bit more horsepower for A LOT more imbalance (especially for big displacement mills like this one).  I'd be afraid of breaking the block at high rpm just from the inertia loads.
You also have to make a pair of custom SOHC cams to work with the new firing order.  Admittedly, the thing would sound awesome!
