Author Topic: BK/BJ reproductions  (Read 16685 times)
Re: BK/BJ reproductions
« Reply #15 on: June 11, 2019, 10:27:52 AM »
Ohhh, I wouldn't have bragged....  machinery has an annoying tendency to prove me wrong anytime I *think* I know something.
« Reply #16 on: June 11, 2019, 10:42:36 AM »
In no way shape or form do I mean to be bashing on Carl's reproductions, they certainly fill a void where the car show enthusiast needs the correct number, and that is cool.
Yeah, not bashing Carl's efforts either. He's a good guy that has helped out the FE community in many ways. If he had demanded the carbs be original in every way, I'm sure they would be 3-4 times the cost, at least.
And underwater demolition is about the only way I could catch a fish.  ;D
« Reply #17 on: June 11, 2019, 11:43:57 AM »
« Reply #18 on: June 12, 2019, 12:56:57 PM »
I dunno if you can view this, if not let me know and I'll try something else:
https://www.facebook.com/AirFuelSParkTech/videos/1231150237067129/
« Reply #19 on: June 12, 2019, 01:01:33 PM »
Works fine
67428GT500
« Reply #20 on: June 12, 2019, 03:52:25 PM »
Drew, not burn my eyes rich anymore? That's outstanding! Thank you!
We can make the peanut gallery start a go fund me page to pay for your research..lol
                                                    -Keith
« Reply #21 on: June 12, 2019, 04:10:51 PM »
Nope, nice and clean idle, mixture screws are at exactly 1 turn out and 12.5a/f is about right for idle (on my car)
Obviously lean when you fire it cold, but once up to temp it does just fine.
67xr7cat
« Reply #22 on: June 12, 2019, 08:41:39 PM »
Oh, and the main reason I posted this thread at all is because I have been hearing forever that the reproduction bk/bj's are just like the originals.
They are not even the same size, you could get much closer with an pre -3 1850, just reduce IAB to .063 and you pretty much have BK/BJ calibration.
HI Drew, interesting post. Question how different would a new 1850 (think calling the street warrior now) be calibration wise from the originals? Am surprised that the pre -3 is so close.
Thanks Steve
« Reply #23 on: June 12, 2019, 08:56:10 PM »
The new 1850's are kinda weird, I wouldn't run one without being able to REALLY inspect it.
1850-1 and 1850-2 are identical to the BK/BJ's with the exception of their IAB being .067 instead of .063
The 1850-3 is the same as the -1 and -2 except it uses an orange pump cam and has no emulsion tube.
67xr7cat
« Reply #24 on: June 12, 2019, 09:14:46 PM »
OK weird seems to always find me....lol. Reason I asked is I have two of them was thinking of using on a BT 2x4.
67GT500
« Reply #25 on: June 13, 2019, 03:05:08 AM »
Hi Drew, what size jets did you end up going with..?  or did you keep them the same.. 60 on the primary carb and 67 on the secondary carb..
67428GT500
« Reply #26 on: June 13, 2019, 03:32:53 AM »
The original primary jets were 66. The secondary plate was a #6, 67 equivalent is what I remember in these carbs. They are both the same primary and secondary jetting/plate size. There were no changes from how they were supplied from Carl's Ford Parts.  They run beautifully on Drew's engine. They should be damn close on mine.
        -Keith
« Last Edit: July 24, 2019, 04:48:02 AM by 67428GT500 »
67428GT500
« Reply #27 on: June 13, 2019, 03:44:18 AM »
Drew:
What did you get the idle down to? 850-900 rpm?
                                         -Keith
GJCAT427
« Reply #28 on: June 13, 2019, 05:15:42 AM »
Thank you Drew for the info. This confirms what a Holley tech told me yrs ago that the 1850s (-1 &-2s) were the same as the BK/BJs. A lot of guys told me I was wrong and they couldn`t be the same. I still look for -1s & -2s at swapmeets but not so much any more as I have a bunch if I get the urge to build another  2x4 set up.
« Reply #29 on: June 13, 2019, 09:06:17 AM »
xr7cat:
When I said "weird' I was trying to be polite.  What I mean, is they are setup way too lean, and often holes aren't drilled all the way through, or there are broken drill bits, etc in the metering block.  I try to be careful about having a blanket generalization about them as each dash number/revision is different from the last one.
67gt500:
Jets in these were 60/67
Same in C3AE-9510-C carbs, 62's in 1849's.
So I kept the stock jet sizes as it makes the most sense.
67426gt500:
66 would be the stock size in an 1850, which as stated the venturi and throttle plates are a different size.  If you put 66's in these, they would be REALLY fat at cruise.
-idle in gear is 900, if you want it lower that isn't hard to do, tho I'd suggest adjusting idle speed via the secondaries.  Since I installed a set screw you can adjust it with an allen wrench while the carbs are installed.
GJCat427:
The only difference in calibration is the idle air bleed, the secondary high speed bleed is slightly different as well, but it isn't nearly as important to overall usage.
A lot of guys tell me I'm wrong still....  They cling to the idea that there was some magic that makes carburetors work together in a pair.
