Author Topic: '62 Galaxie Progress Report  (Read 140170 times)
« Reply #120 on: February 22, 2023, 03:25:20 PM »
Ah, but she was right! Sorry.
Hey your work paid off as man that is a clean underside!
galaxiex
« Reply #121 on: February 22, 2023, 08:20:53 PM »
I cleaned the fairly thick factory tar like undercoating from my 66 Galaxie with a cold water pressure washer.
No soap either.
Hate Honda's?
That little 13 horse Honda driving a nasty 4000 PSI pressure washer, peeled the undercoating off like you wouldn't believe.
Honda ran like a champ the whole time.
Used a narrow jet on the wand, I think 10 or 15 degree?
All that was left was a "very" thin film of goo that wiped off easy with some rags and varsol.
Left the bottom spotless.
I got a little wet from the water, but it was a walk in the park compared to my buddy that used a propane torch and a scraper on his car.
I read about this method years ago in HotRod magazine.
I think the article was by Frieburger.
Maybe this will help someone?
Just don't point the nozzle at any paint you care about. It will rip it off before you can blink.
Sorry, I didn't take any good close pics of the bottom after it was done,
but I can assure it was clean!
You can kinda see some of the clean spots in the pics,
and the goo on the concrete pad that used to be on the car.
« Last Edit: February 22, 2023, 08:29:43 PM by galaxiex »
« Reply #122 on: June 05, 2023, 09:30:10 AM »
Some recent progress.
« Reply #123 on: June 11, 2023, 11:30:48 AM »
Just about done now. It gets exciting at the end
6667fan
  • Every Second Counts
« Reply #124 on: June 11, 2023, 03:12:24 PM »
Beautiful.
Looks like Gal City in there.
JB
67 Fairlane 500
482 cid 700/617
10.55@125.74 1.46 60’
« Reply #125 on: June 12, 2023, 08:28:11 AM »
Definitely, I've felt my enthusiasm for it increasing. Just picked up the engine block for it from the machine shop Friday....I think my next updates will all be engine related.
CDXXVII
« Reply #126 on: June 24, 2023, 08:25:17 PM »
My Dallas built '62 Galaxie is just about the opposite. Mostly stripped in pieces.
If the tan/green paint on the underside could be deciphered into a paint mix recipe I would definitely want to use it on mine.
CDXXVII
« Reply #127 on: September 18, 2025, 02:36:52 PM »
Mike,
I see you're still active here. What up with the '62 Gal?
« Reply #128 on: September 19, 2025, 09:20:45 AM »
Well, honestly I've been putting my free time into the drag car, so the Galaxie just sits there and stares at me while I work on the race car. I'm thinking within the next month or two I'll be able to shift my time back to the Galaxie. I have a personal goal of having it running before the end of the year. That's only a couple months away!!
« Reply #129 on: September 19, 2025, 10:02:58 PM »
Get on the stick
« Reply #130 on: September 22, 2025, 03:28:12 PM »
You guys peer pressured me. I got it back in the 2 post lift position this weekend. Gotta get after it.
CDXXVII
« Reply #131 on: October 12, 2025, 08:15:59 AM »
No pressure from this side. I am the last person to be able to preach on the progress of the car project!
« Reply #132 on: December 02, 2025, 05:00:25 PM »
Short block is done, got the timing set on and degreed in this weekend. I think next weekend I'll get some more parts bolted on it, see how far I can get.
It's a 445", pretty common to what everyone is doing now. Hydraulic roller cam. Nothing too trick about it, just a solid engine to drop in the Galaxie.
fitter
« Reply #133 on: December 08, 2025, 08:46:16 AM »
Will you be using your new heads on this build ?
« Reply #134 on: December 08, 2025, 06:07:04 PM »
No sir, our heads aren't quite ready and I'm getting impatient. Just want to see it run and drive. I'll likely switch the heads out when our MR heads are produced. There's a chance this engine makes it into the car with our MR heads on it, but as of right now I'm just bolting a set of TFS heads on it.
