Author Topic: Holley question.... ( a few more questions )  (Read 8983 times)
winr1
« on: April 07, 2019, 09:35:16 PM »
Rebuilt a Holley 600 Va. secondary for my 352, runs nice now
Used a Quick Fuel rebuild kit, had the black bowl bolt washers, the diameter is small but squish out
Had to tighten the front bowl bolts more than the rear bowl bolts
The placement hole on the front bowls are larger than the placement holes on the rear bowl
You can see the washers on the rear bowl after tightening
The front washers squish to where the built in bolt washer touches the bowl
Gonna get some regular washers but was wonderin want yall use ??
Also, on the carb, I did not notice till the mill was running
There is no ported vacuum on the metering plate ??
I need this for my vac. advance on my distributor
Any way to fix this versus getting another metering plate ??
Ricky.
« Last Edit: April 11, 2019, 09:43:44 PM by winr1 »
Re: Holley question.... ( actually several )
« Reply #1 on: April 08, 2019, 08:06:02 AM »
I always use Holley kits.  Have heard stories of problems with using other people kits.  Nothing horrible, but like yours, the stuff is not quite "right".
I've started using the black plastic washers for fuel bowl.  Holley gives them with every kit now.  Much more reusable compared to the paper gaskets from years back.  Never had a leak or issue with them.
As for ported vacuum?  How about drilling a hole and installing a pipe fitting?  Or can you buy the correct plate?  I'll dig through my pile of 600 stuff and see if I have another plate with a port fitting.  It's yours if you need it.
shady
« Reply #2 on: April 08, 2019, 09:04:54 AM »
on my 600s, the vacuum port is right under the front of the sec. vacuum diaphragm. if the brass nipple is missing, easy to miss or maybe it is plugged.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
RJP
« Reply #3 on: April 08, 2019, 11:34:33 AM »
I've had problems with the black plastic washers leaking. Chased a stubborn weeping that I thought was the accelerator pump cover. After resurfacing both cover and bowl it still weeped, not alot, just enough to dampen the bottom part of the bowl with an occasional drip. Pulled the bowl, mounted in the mill and using a 4 flute end mill spot faced the bowl screw surface and found it took about a .009-.010" cut to true up the mating surface. The old paper gaskets would conform to just about any surface for a fuel tight seal...The plastic washers? Not so much. I now spot face all bowl screw surfaces as SOP when I build a Holley.
« Reply #4 on: April 08, 2019, 12:03:53 PM »
Interesting.  I can see it happening though(and at first was skeptical).  Guess I've been real lucky up to this point?  Or the fact that all my carbs are over 20 yrs old, they were machined better back then?
winr1
« Reply #5 on: April 08, 2019, 05:02:15 PM »
Thanks much guys !!
I will look at the Holley again and see what I can see
Ricky.
RJP
« Reply #6 on: April 08, 2019, 05:39:43 PM »
Or maybe lived a charmed life? I've found the problem on both old and newer [less that 10 y.o.] I've used other plastic washers, mainly white ones from a hardware store. A little thicker but a 'reusable' type. I haven't had any problems until using the Holley black washers. Maybe they are a lot harder and don't conform as easily.
« Reply #7 on: April 09, 2019, 09:35:03 AM »
Same.  I had to pick up an Edelbrock kit for a 4160 at Pep Boys because I needed pump diaphragms and that's all they carry.  It was at least decent and got me by for a bit.
winr1
« Reply #8 on: April 11, 2019, 09:42:49 PM »
The pics are of the carb I need a vacuum cover for ....
Any have a vacuum secondary cover ??
Also, Tommy or anyone that has a front jet plate with a ported vacuum tube on it
And.. any ever see a holley with just the aluminum rear plate, no thin plate in between ??
The 600 Holley I was rebuilding earlier has only the aluminum plate ??
Secondary sealing plate for use on model 4160 carburetors that have a power valve cavity on the secondary side.
https://www.holley.com/products/gaskets/carburetor_gaskets/parts/108-122?gclid=EAIaIQobChMIqefny9XJ4QIVxrrACh2PMA5ZEAQYAiABEgIDjvD_BwE
Ricky.
« Last Edit: April 11, 2019, 11:07:51 PM by winr1 »
Re: Holley question.... ( a few more questions )
« Reply #9 on: April 12, 2019, 04:42:46 AM »
I guess I am getting old - I actually prefer the paper washers.  They seal well and have a little give to them and don't put all the clamp load against the bowl and block gaskets.
I had one of those really inexpensive Holleys come in on a customer project.  It had no sealing gasket or thin metal plate behind the die cast secondary metering plate.  I decided that was doomed to fail in service from eventual gasket deformation, found a plate & such from my stash, installed them, and continued on.
fordman460
« Reply #10 on: April 12, 2019, 05:57:03 AM »
.Holleys that I have had that didn't use the thin metal plate didn't have a power valve cavity.
« Reply #11 on: April 12, 2019, 07:51:19 AM »
Not that I go through my carbs very often, but nice not to have to keep buying those little paper gaskets for fuel bowls.  I was skeptical of the plastic rings, but all my hot rods have them without issue(everything I own has 2x4's on it).
I'll poke around in my Holley junk box this weekend and see what I have extra.  Should have something.
« Last Edit: April 12, 2019, 07:56:06 AM by BattlestarGalactic »
winr1
« Reply #12 on: April 12, 2019, 11:05:46 AM »
Thanks guys !!
I found some fiber washers at ace, a bit thicker than Holley paper washers
They fit the bolt well and the bowl relief as well
I have a good metering plate and a center hung bowl if anyone can use them
Ricky.
« Reply #13 on: April 14, 2019, 07:50:02 PM »
Something like these:
winr1
« Reply #14 on: April 15, 2019, 01:27:18 AM »
Those look what I need
I noticed the vacuum port, all the 4160 carbs I have seen had a pressed in tube
The plate I have has a large large hole where the tube would be pressed in
Perhaps 2 different castings ??
The one with the large hole may be drilled into ported vacuum and the hole threaded from factory ??
Are they spares ya do not need ??
I would gladly pay ya or trade for them... 427 block, stack of hundreds, milk an whiskey .....
Ricky.
