Author Topic: High Torque FE/MEL In Front Of A 16 Spline Dana 60  (Read 8728 times)
chris401
« on: March 01, 2019, 02:24:18 PM »
The original 16 spline Dana 60 that came in the 65 F-250 is the smallest 3/4 ton axle I have personally owned. No problems with the 352 towing up to 19,000 gvw. Like any other Dana I remember the fat end has the splines and are cut no deeper than the shaft itself. Gearing will be 3.54 and would like to keep the original Dana 60 axle. I know bolt in 70s are out there. If I cut anything to fit it will be a Sterling 10.25".
Excluding the rock crawlers has anyone here had problems with a farm/highway towing Dana 60 behind 500lbs of towing torque?
TJ
Re: High Torque FE/MEL In Front Of A 16 Spline Dana 60
« Reply #1 on: March 01, 2019, 06:29:44 PM »
The FE in my 65F250 makes over 600 lb ft.  I've never had GCW over 16,000 lbs, my differential is open, and I don't mash the hammer in low gears when loaded.  With under 16,000 lbs, I haven't needed to mash it to achieve or maintain freeway speed.
chris401
« Reply #2 on: March 01, 2019, 09:22:07 PM »
Is yours the 4:10 60 wih the axle hub studs and cones? When I was looking at a 16 spline locker I was also looking at shaft availability.
TJ
« Reply #3 on: March 02, 2019, 10:44:32 PM »
Ratio is 4.10 and original.  Been 14 years since I had it apart and can't remember if it has cones.
chris401
« Reply #4 on: March 03, 2019, 06:39:17 PM »
Sounds like it is the same axle. The cones are behind the nuts where the axle flange bolts to the hub.
BigBlueIron
« Reply #5 on: March 04, 2019, 03:24:02 PM »
That is the old wedge lock style and they SUCK trying to pull out. I doubt you will have any issues at 500ftlb.
RustyCrankshaft
« Reply #6 on: March 05, 2019, 02:17:30 AM »
Those cone locks for axles are still used on big trucks and industrial axles to this day. The weakness in that axle is at the splines, if you aren't twisting the spines on the axle or tearing them out of the spider it'll be just fine for a long time.
NIsaacs
« Reply #7 on: March 05, 2019, 06:34:41 AM »
Smack the end of the axle flange with a good sized hammer, they will pop right out. Don't hit any of the studs, lol
chris401
« Reply #8 on: March 05, 2019, 08:47:34 AM »
I have fished out a broken axle a couple of times as a mechanic but not to the degree I have read about. Thought I may have missed something. My concern was having a replacement axle avliable if I break one out of state. I see it mentioned boring out the old or welding new spindle on to accomodate 35 spline axle shafts. I do not like the idea of taking metal away for a larger shaft, anyone with experience?
RustyCrankshaft
« Reply #9 on: March 06, 2019, 02:42:05 AM »
I usually leave the nuts on a few threads to help protect the studs and to keep the cones from flying all over the busy freeway. Because there is nothing like chasing those litter buggers all over the road at 2am in the rain with oily hands.
HarleyJack17
« Reply #10 on: March 06, 2019, 10:51:18 AM »
[quoteI see it mentioned boring out the old or welding new spindle on to accomodate 35 spline axle shafts.][/quote]
Not sure where you heard that unless you are dealing with a really early axle version.  I went through three housings on my 75 Highboy to make one....loooooong story.
Anyway, the original had 16 spline shafts. Other two were either 31/35 I can't remember.  The spindles and hubs all looked the same and I know I threw the axles side by side...only difference was the spline count. I ended up using the ring and pinion from my original housing, the carrier and spiders and brake parts from a dana 61, and put it all into a late 70s/early 80s housing after cutting and repositioning the axle perches to match my original High Boy axle. Lot of part swapping. If my memory was better I could tell you 100% for sure but at the time that happened I had a lot of stuff going on.  Either way I drove the snot out of it and zero issues.
16 spline axles are a lot stronger than people want to admit.  Just as an FYI lot of big trucks run less splines, but bigger cuts....go look at a 2 1/2 or 5 ton military axle.....looks a lot like what you have, only bigger.
chris401
« Reply #11 on: March 06, 2019, 12:46:04 PM »
[/quote]
I looked at a 77 Highboy and a couple of bump side 60's that had the spring perches in the same location as my 65. Interesting thing was there was an 1 1/2" difference between backing plates, mine being the narrowest. Seems like the 77 was the widest.
chris401
« Reply #12 on: March 06, 2019, 12:51:12 PM »
That clears it up, Your experiences go along with what I haven't seen in the shops.
Thanks
HarleyJack17
« Reply #13 on: March 07, 2019, 12:17:24 PM »
Chris,
Yeah you touched on something and sparked my memory....not talking overall axle width end to end...but Highboys(F250 4x4) had a narrower frame than 4x2 trucks. Now what Ford did to "fit" the axle I am not sure....when measuring be sure to look at perch to backing plate and perch to carrier housing...Like I said, the final housing I had the perches were spaced to wide so I had to cut them and weld new ones in the proper place.  I was told the axle was out of a '79.
It is easier for Ford to move perches than use completely different housings. Again, what I know applies to late 60's to mid-1970's Highboys since there was little variation in the frames and suspension if any.  Mainly the body and wiring changed for those trucks.
Hope it helps. Fordification has some good info on it just an fyi.
chris401
« Reply #14 on: March 07, 2019, 08:52:08 PM »
Chris,
I do not recall the distance between the 65 perchs but it is the same as the Highboy I looked at. In 1973 Ford did widen there 2 wheel drive pick-up frames by 3". I was going to wait and do the axle, Browne and Clark all at one time but this thread put me at ease about running the 60 as is. Unless I find something wrong with the Clark I would like to have everything installed by May.
