FE Technical Forum
2d Elect Oil Pressure guage
Topic: 2d Elect Oil Pressure guage (Read 4388 times)
MHarvey
Jr. Member
November 10, 2018, 02:18:07 AM »
How would I install a second oil pressure gauge...I believe just connecting a second gauge to the same sensor will provided a reduced reading...but where would I install the second sensor?
Re: 2d Elect Oil Pressure guage
Reply #1 on:
November 10, 2018, 02:26:23 AM »
In the past, I have always just used a brass Tee fitting on the oil filter adapter, so I could retain my factory oil pressure gauge or idiot light, as well as an aftermarket mechanical gauge. Worked just fine.
MHarvey
Jr. Member
Reply #2 on:
November 10, 2018, 02:44:26 AM »
thanks...simple and cheap
MHarvey
Jr. Member
Reply #3 on:
November 10, 2018, 11:49:34 PM »
I did see a more cosmetic option..a sandwich adapter...but what one fits....most do not go back to 1969
gdaddy01
Reply #4 on:
November 12, 2018, 11:03:55 AM »
be carefull with the brass Tee fitting, the cheap ones are cut to thin and will break off at the threads .
Reply #5 on:
November 12, 2018, 12:31:58 PM »
^^This.
I had one crack/break on the wagon many years ago. I ran a low pressure switch to my fuel pump. It cracked, leaked and I have to do surgery on it on a Sat at the track. Never did reinstall that switch.
Diogenes
Sr. Member
Reply #6 on:
November 12, 2018, 02:52:37 PM »
You should be able to find a steel tee to use, instead of brass. NAPA stores typically have a selection of steel fittings.
WHEN CRIMINALS MAKE THE LAWS, OBEYING THE LAW IS A CRIME.
1966 Galaxie 500 390 Toploader 3.89 Traction-Lock 9in.
1985 Toyota Celica Supra
1971 Montego MX wagon 351C Toploader Detroit Locker Cyclone competition gauge/dash bucket seats/console
1989 Texas DPS Police Mustang
1971 Torino GT 351C 4V AT
1968 Cougar 351W Toploader Traction-Lock 8in.
1989 Dodge Omni modified 2.5 turbo from hell
FE Technical Forum
