Author Topic: 66 Comet drag car  (Read 11979 times)
Jim Comet
66 Comet drag car
« on: July 05, 2018, 10:26:11 AM »
I am making slow progress on my car as my budget allows. I am having Blair put together a 390 based 416 with a steel crank, Molnar rods, CP custom pistons, his pro port heads, baby solid roller cam and the new Trick Flow or my Performer RPM intake depending on which performs better. I am guessing it will make 550+ hp. I have locked the timing out per Blairs suggestion and this will be a drag only car so the converter will flash past any advance curve it would have had. Does anyone have any experience with the MSD starter saver? Are you pulling 10 or 20 degrees out when starting? My transmission is a C6 with the Motorsports low ratio planetary and needle bearing kit. Are there any components that that I should look to change for durability sake at the expected higher hp levels. The trans had the D servo and F lever in it along with good and extra clutches. Does anyone know of someone in the Twin Cities area with experience in building/rebuilding these transmissions with the needle bearings? I am nervous about trying it myself knowing the clearance are critical on the needle bearing setups. Here is a picture of the Car and the passenger side header I built. The headers are 1 7/8 transitioning to 2 inch into a 3 inch collector. Thanks, Jim
« Last Edit: July 05, 2018, 09:40:19 PM by Jim Comet »
Re: 66 Comet drag car
« Reply #1 on: July 05, 2018, 10:35:50 AM »
I haven't used one, but assuming it'll be a pretty stout engine and locked around 34 degrees, I'd pull out 20.  That puts it at a very normal 14 for hot starting between rounds and as soon as you release the key it should go right back to locked amount.
A second option would be to just have the ignition wired on another switch and get it cranking and flip the ignition on, but I sort of like the "normal operation" using the key with your plan
Your tranny should have all it needs IMHO
« Reply #2 on: July 05, 2018, 10:38:48 AM »
I don't know anything about those auto-matic thingys, but you sure did a nice job on that header.
gt350hr
« Reply #3 on: July 05, 2018, 11:50:14 AM »
   Jim ,
      I converted my own C6 to the low gear setup. I had "most" but not all of the parts. (I didn't get the complete kit). I bought what I was missing , down loaded the Ford racing instructions , opened the Shop manual to the C6 section , and went at it. It was actually pretty easy in retrospect.
   +2 Nice job on the headers!!!!
   Randy
FElony
« Reply #4 on: July 05, 2018, 02:09:12 PM »
   Jim ,
   Randy
What are you two guys going run for rear gears?
FElony
« Reply #5 on: July 05, 2018, 02:12:21 PM »
...and the drivers side header I built.
Nice work, but I'll pay big bux to watch you install that on the driver side.   ;)
57 lima bean
« Reply #6 on: July 05, 2018, 02:24:38 PM »
Jim...I had Shepard Transmissions do two low gear C6's for me.There is a steel on steel issue that he dealt with by machining and using a C4 converter bushing you may want to talk with him about.Car is looking good.....pm me.
« Reply #7 on: July 05, 2018, 02:46:16 PM »
   I've built two C6's using the Motorsports wide ratio roller bearing kits, they are pretty straight forward and complete, but I will note one thing - the instructions in mine said to use forward clutch drum E9TZ-7A360-A, which is machined and clearanced for the roller bearing assembly, instead of the forward drum the earlier C6's used with the solid thrust bearings. The problem though is the E9TZ-7A360-A drum had been discontinued by Ford a few years earlier and replaced by a F81Z-7A360-AA forward drum. The F81Z-AA drum will not work with the kit because it does not hold the C6 input shaft in the proper place ( it allows it to slide rearward ).  I was able to have my Ford dealer locate a couple obsolete new drums using their locator service, but that was quite a few years ago now, I don't know if there are still any out there, sourcing a good used E9TZ-A drum may be the only option ( which is fine ), or it may be possible to machine the pocket deeper on the earlier C6 forward drum. I don't remember off the top of my head if the instructions had advice on that, it may have. Otherwise the Motorsports kit assembled fine, everything fit fine, and there were no issues. The final geartrain endplay still needs to be checked & set, but that is done as normal with the selective #1 thrust washer, and you may need to obtain the one you need from a transmission parts supply business if you don't have a selection on hand, but they are easily purchased.
As far as any other things to do, do you know how many Reverse-High ( Direct ) clutches your current drum holds? I usually use a 5 clutch drum myself. 5 clutch Reverse-High ( Direct ) drums were used in some high torque C6's stock, and are available from most of the Transmission supply businesses. Ford Motorsports used to have one available too, but it has sadly been discontinued. One was for sale on the forum here recently, but was snapped up quick.
I've used "H" servo's in my C6's, some already had the "H" servo, or I've been able to find some used ones when needed. They have functioned fine, but I'm not pushing an extreme amount of power.
Do you know what year C6 transmission case you have? The '66- to somewhere in '69 C6 case used splash oiling for the one-way clutch at the back of the geartrain and was prone to failure. Starting in '69 Ford switched to a pressure oiled one-way clutch. It's very easy to convert an earlier C6 case to the pressure oiling, and the Motorsports wide ratio roller bearing kit comes with the proper pressured oiled one-way clutch inner race, if you have an earlier case let me know and I can detail what needs to be done, if you have a later case it will be set for the pressure oiled one-way clutch already. Even if someone isn't doing a performance C6 build it's well worth updating to the pressured oiled one-way clutch, almost every old pre-'69 C6 I've worked on had a failed one way clutch, or was on it's way to failing.
I always check the pump gears and replace if needed, they are relatively cheap. I always have a new convertor bushing installed in the pump too. I generally have my mechanic buddy BradFord install the pump bushing because even professional transmission shops don't seem to know the proper direction to install it ( the bushing has an oiling slot ) and if done the wrong direction it can result in seal failure at some point.
Jim I'd be happy to give you some help if needed, but I won't be able to until August, I don't know what your time table is, just let me know.
Jim Comet
« Reply #8 on: July 05, 2018, 02:47:18 PM »
"Nice work, but I'll pay big bux to watch you install that on the driver side.   ;)"
No shock towers should help. The drivers side has to go in in pieces as it goes around the steering shaft for my rear steer rack & Pinion.
FElony
« Reply #9 on: July 05, 2018, 03:00:10 PM »
Isn't that a passenger side header?
shady
« Reply #10 on: July 05, 2018, 03:25:22 PM »
turbo headers.
2021 FERR cool FE Winner
2022 FERR cool FE Winner
2023 FERR cool FE Winner
Jim Comet
« Reply #11 on: July 05, 2018, 03:48:08 PM »
You are correct. I am hoping I can install that side to the motor and install it with the engine/trans assembly.
FElony
« Reply #12 on: July 05, 2018, 03:58:37 PM »
OK, let's review. You said it was a driver's side header. It is obviously a passenger header, which is why I kiddingly said that I'd like to see you put THAT header on the driver's side. Get it?
Jim Comet
« Reply #13 on: July 05, 2018, 04:02:00 PM »
Kevin, my transmission was built with the M-7398-F kit and I believe the number 1 thrust washer was replaced with a needle bearing also. The trans guy had to do some machining to install the #1 bearing. The guys name was Jim and he ran a small shop in Elk River out of his garage called Perfective Performance transmission but unfortunately he move out east.
Steve, I currently have a babbit pump bushing in my pump. I had some converter hub issues until I switched to the babbit style bushing which eliminated my problems.
So the transmission has about 500 passes on it and about 2000 street miles. It worked fine when I took it out. Does a guy rebuild it to play it safe or would you run it? Jim
Jim Comet
« Reply #14 on: July 05, 2018, 04:03:59 PM »
Felony, I get it now! This 4th of July in Delano took a lot out of me. I'll try and pay better attention starting tomorrow. Jim
