Author Topic: intake to block gap  (Read 17957 times)
intake to block gap
« on: October 03, 2017, 04:54:31 PM »
test fitting a intake with the intake to head gaskets in place,what is the normal gap at the front and china walls.my cork front gasket slips in and out easily with slack,is this normal or should the gap be smaller
Ranch
Re: intake to block gap
« Reply #1 on: October 03, 2017, 05:12:22 PM »
Before you do anything you might want to take a look at how the ports match up (manifold / head) with a bore scope. "Maybe'?? your intake needs a trimming...JMO
« Reply #2 on: October 03, 2017, 07:36:02 PM »
NEW BBM HEADS,NEW RPM INTAKE,GAP IS 1/16 BIGGER THAN THE CORK GASKET
« Reply #3 on: October 03, 2017, 07:47:16 PM »
Shine a light down the 4 corner bolt holes and see if the intake's holes line up well with the head's. That or try and start the 4 corner bolts by hand.
« Reply #4 on: October 03, 2017, 09:41:08 PM »
ALL THE BOLTS LINE UP FINE AND WILL SCREW IN BY HAND,THE VALVE COVER RAIL LINES UP GOOD,AND THE INTAKE FITS AGAINST THE HEADS GOOD TOO.IM JUST WONDERING HOW MUCH FRONT GAP IS NORMAL AND HOW MUCH IS TOO MUCH.
« Reply #5 on: October 03, 2017, 10:16:43 PM »
Then your good to go. Use Right Stuff or another silicone sealant instead of the corks. Or corks and sealant.
« Reply #6 on: October 04, 2017, 12:19:53 AM »
thank you Bob,i have a tube of right stuff on its way,i should get it tomorrow.
« Reply #7 on: October 04, 2017, 05:08:25 AM »
Make sure the head gasket tabs are not holding the intake off the heads.
But this is why I don't mess with cork end gaskets.  This is all too common with aftermarket combinations and it's just not worth the time to fit cork when you can lay a bead of silicone down and roll with it.
Skip the Right Stuff though.....I've had porosity leaks from that stuff.  Barry uses Motorcraft TA-31 and I use Dow Corning 732.
« Reply #8 on: October 04, 2017, 06:19:18 AM »
No secret I am not a silicone fan, but I have not tried some of the new stuff.  I will say that I do not like Right Stuff.  IMHO it's messy glue that often has internal bubbles.
The thing that gets me is "too much space"  I have never had that issue.  Especially with something like a Felpro end seal and an RPM, in fact, every RPM intake I have has needed to be trimmed and I even mix and match cork gaskets to get the crush I want.
I am not sure what you are using, Mr Gasket gaskets are nice, but I toss their end seals usually.  More often than not, the issue is not enough space after a cut deck and heads.
I'd look close for the cause, now, if the ports line up and the angles to the head look correct, head gasket tabs aren't hanging the intake, certainly cannot argue that the end rail cork won't work, they need to be compressed, but I just haven't see that
As far as time to fit, it's all a trade, time to fit, or time to dry, depends on your schedule, neither way is a free ride.
« Reply #9 on: October 04, 2017, 06:33:44 AM »
I had my fill with Right Stuff.  It is gooey and is like working with never-seize or machinist dye.....you'll end up with it from head to toe by the time you're done.  It also let me down once, so never again.....
The Dow Corning 732 isn't gooey but is very easy to use.  It fills voids and is easily smoothed and shaped without getting it all over you.  Its very oil resistant, and on an FE, it will be dry enough to use by the time you get the intake on, pushrods and rockers on, carbs on, water crossover on, etc.
scott foxwell
« Reply #10 on: October 04, 2017, 10:17:43 AM »
Drop in the distributor before you go any further. That's first priority. If this isn't a race deal don't worry too much about port matching unless there is a gross mismatch. If the valve cover rails match up and the distributor drops in, then you can look at port matching. If the valve cover rails line up now, you can't take much off the intake to correct any port mismatch.
« Reply #11 on: October 04, 2017, 12:24:37 PM »
i had used the right stuff the last time and i did see bubbles in it when i removed the intake.i have the mr gasket 202a intake gasket.the cork seemed thin to me.i have some 732.i will give it a try.everything looks good.i was just concerned when i saw how thin the corks were in the mr gasket kit
« Reply #12 on: October 05, 2017, 08:54:54 AM »
I use a bead of silicone - black high temp - on all china walls.  Take a look at the gap first, then lay a bead a little taller making sure it's the right height where it meets the intake gaskets.  Let it set up for a bit, about 20~30 minutes.  Then smear a see through swipe of silicone on the intake ends and set the intake straight down on the heads.  Guide pins or studs will help that.  Snug the bolts a little more than hand tight, then finish torque about 24 hours later after the RTV sets up.  Done carefully, I never had leaks nor is RTV accidentally introduced into the engine.  That is critical because RTV will go kinda plastic in hot oil and end up in places you'd rather it not.  (shout out to those that use a whole tube to install an oil pan LOL).
If the gap is much more than 1~1 1/2 of a cork gasket, better think about a Plan B because I'd not be keen about having a big tall bead stay in place.  The AFD heads on my 351C place the intake about 1/2" above the china walls - I make an aluminum pan to cover the space.
« Reply #13 on: October 05, 2017, 09:25:13 AM »
I routinely have to lay beads about 1/2" tall on some of my CHI headed small blocks.  No problems whatsoever.  You can see it on this build here:
http://www.mustangandfords.com/how-to/engine/1702-700hp-can-be-yours-by-building-a-boss-style-stroker/
Look about 3/4 way down the page and there's a front shot of the completed engine.
I've had factory Tunnel Wedges on Pond blocks, where the front face of the intake actually sat mostly behind the front china wall on the block.  If it weren't for silicone, I would have had to order blocks of cork, then shape it down.   I can't justify spending that much time on it when I can lay silicone down and be done.
« Reply #14 on: October 05, 2017, 07:34:58 PM »
Brent,i saw the thick silicone in the pic.my gap is tiny compared to that one.im sure i will be fine with it.  thanks
