FE Technical Forum
Lazy rpm rise
Topic: Lazy rpm rise (Read 3539 times)
preaction
Sr. Member
Lazy rpm rise
June 12, 2017, 12:25:43 AM »
What would be a factor for a carb being lazy in raising rpm's.
Tobbemek
Jr. Member
Re: Lazy rpm rise
Reply #1 on:
June 12, 2017, 01:45:27 AM »
You have to give us more info. about engine, carb and so on. is the engine bluddering, stumbling, surging, ore is it clean running just lazy.
1 throttle plates not opening properly
2 Ignition timing of, Ignition advance weights stuck in distributor
FE Technical Forum
Lazy rpm rise
