Author Topic: Maverick Project  (Read 53886 times)
mn67
Maverick Project
« on: March 10, 2017, 08:22:32 AM »
Since my O.C.D and A.D.D were fighting each other it has been a hard decision on what car to put the 445 in. I have a couple, so like any good Ford obsessed guy that can't decide on a direction. I took a ride into the country and found a new one. The others are now on mothballs waiting for the next go round and this comes home tonight. In the end power to weight ratio won out. There was a pinto there also but he didn't want to part with it. Should be fun!
« Last Edit: March 10, 2017, 08:42:21 AM by mn67 »
1971 Maverick Grabber
Bolted to Floor
Re: Maverick Project
« Reply #1 on: March 10, 2017, 09:13:58 AM »
That should be fun to drive.  ;D
« Reply #2 on: March 10, 2017, 09:47:56 AM »
You might want to check out Blizz's 351C Maverick here:
http://351c.net/board/index.php?/topic/4207-blizzz-70-maverick-spro-chassis/#comment-12782
An all out race car for sure but he did trash the old 1/2 chassis and bought an entirely new 100% tube chassis and stuffed same under the body you'll see in the background.
mn67
« Reply #3 on: March 10, 2017, 09:53:00 AM »
Great car. I will not be going that radical, just a pooch of a street car is what I am after. Or at least it will look that way.
« Reply #4 on: March 10, 2017, 11:21:37 AM »
Cool. Is that an original Grabber? I have a soft spot for Mavericks, particularly the older narrow bumper ones. I've had several over the many years, including 2 original V8 models and a Grabber. It doesn't take much to make them quick.  You must be planning on a Mustang II front end, cause there's no way that FE is fitting between those shock towers.
mn67
« Reply #5 on: March 10, 2017, 12:13:04 PM »
Doug, It is an original Grabber. I will be notching the towers kind of like the Crites kit, or get a custom tower out of Brasil.
« Reply #6 on: March 10, 2017, 01:44:56 PM »
Thatll be a cool project, and plenty fast when you're done. Hope you keep us updated.
mn67
« Reply #7 on: March 10, 2017, 02:05:04 PM »
Thanks Doug I will be sure and update regularly. I do need to get around to putting the 445 on a dyno.
mn67
« Reply #8 on: March 10, 2017, 07:38:29 PM »
It's home. Time to start the project.
482supersnake
« Reply #9 on: March 10, 2017, 09:35:05 PM »
Changing the spark plugs in my sisters 302 powered Maverick was worse than changing them in my big block 67 Cougar. :o
Have fun. Cool project.
mn67
« Reply #10 on: April 03, 2017, 12:41:19 PM »
Finally had a day to work on the Maverick. It is a surprisingly solid car I will be taking it completely bare so there will be a surprise or two I am sure. I have all the measuring done and will get it stripped down and the towers notched this week. The 302 was a tight fit. The FE is going to be pretty tight even after the notching. I see custom headers in my future.
« Last Edit: April 03, 2017, 12:46:25 PM by mn67 »
« Reply #11 on: April 03, 2017, 01:12:30 PM »
Long ago, and I do mean the 70's, IIRC someone did make swap headers. But, since the car is so old and the swap was kinda' rare maybe none exist today. Maybe it was Headers by Ed.
« Reply #12 on: April 03, 2017, 03:01:01 PM »
My old Hooker headers catalog "claims" that the multi piece FE Mustang/Fairlane "race" headers also fit a Maverick with a FE swap, but I really can not believe that they would, at least without major surgery. Before I bought my current 78 Fairmont in 1986, I had bought a 71 Maverick that a buddy had built that I planned on swapping my FE into. He had ran in with a 351C ad 4 speed,,a local chassis shop had eliminated the Mavericks shock towers. What they did was to remove all the inner fenders and shock towers, leaving the stock frame rails, firewall, & radiator support. He then shortened the lower control arms 3" per side, and moved the inner pivot box outboard by the same amount. He made 1 3/4" tubing braces that ran from the front of the frame rails to the firewall, and to those, he made tabs for fabricated tubular upper control arms, and the upper mounts for the Koni coil overs. He also narrowed a Pinto steering rack, and swapped the spindles side for side, so the steering arms pointed straight ahead. He mounted the 351C with a motor plate, used a rear sump oil pan from a 351 1978 Bronco, and mde up a custom set of headers. I bought the Maverick less engine and trans, but once I had my Fairmont, I sold the Maverick to a couple of local racers who ran it with a 351 C and C4. They sold the car about 10 or 15 years ago, have not seen it since. But I have always thought that Mavericks make great looking drag cars.
mn67
« Reply #13 on: April 03, 2017, 03:26:42 PM »
I was planning on taking a more simple approach. This is one a friend did quite a few years ago. Not the cleanest job but same idea. He did have custom headers. Long way to go yet before I need to cross the header bridge. There a few guys around that make a nice header when the time comes.
« Last Edit: April 03, 2017, 03:29:44 PM by mn67 »
« Reply #14 on: April 03, 2017, 08:00:25 PM »
That actually looks pretty good, more room there than I thought, and not an extremely complex job...
