Author Topic: Disease please, I'll take two.  (Read 152489 times)
« Reply #135 on: June 22, 2017, 05:17:38 AM »
Wiring! Sigh......
Maybe someday car electronics will progress to wireless. Imagine only needing to run big power stuff (headlights,starter, alternator, battery) with traditional cables while all the rest operates wirelessly.
Sounds crazy and impossible but.....
« Reply #136 on: June 22, 2017, 06:46:20 AM »
 ;D just like a Model-T then. Before -19 even the starter was wireles ;D
« Reply #137 on: June 24, 2017, 02:19:09 PM »
Well I'm heading into my second week of wiring. :P
Finishing up the power station mockup.
Definitely time to clean up this mess and make a new one.
« Reply #138 on: June 25, 2017, 06:32:02 AM »
Marc, I'm not clear from the pictures how you are getting the power wires up to the location under the dash.  Are you running them through a starter solenoid first, and having the solenoid act like a switch?
If so that might be a problem, because if I recall correctly the starter solenoid contacts are not rated for continuous operation.  In fact, I think I may have actually tried that years ago and had problems; can't remember its been so long...
Leny Mason
« Reply #139 on: June 25, 2017, 07:51:06 AM »
Hi the only thing I see wrong is the color code on the battery I even sell I Interstate battery's but on your car so nicely done it looks wrong sorry, and jay they make continuous contact solenoids that work fine, please don't take offence on my statement. Leny Mason
« Reply #140 on: June 25, 2017, 08:07:17 AM »
That's why I included a picture of the wiring.
Was hoping for any problems to be caught ahead of time.
Jay I'm doing it like I remember normal truck/car setups. I may be wrong so I appreciate any comment.
But there is constant power to the legs. All feeds are connected on one side of the solenoid. The solenoid is only used for the starter which is hooked to the opposite side.
« Last Edit: June 25, 2017, 09:37:39 AM by turbohunter »
« Reply #141 on: June 25, 2017, 08:17:45 AM »
Hah Leny, you're right but I figured utility over art on this one. ::)
The battery is Interstates new (?) AGM. It is a pretty damn hot battery.
800 cca
1000 ca
125 rc
« Reply #142 on: June 25, 2017, 11:40:07 AM »
LOL, go back a couple more years and even the headlights were wireless ;D
Marc, just curious, but what do you have that requires 3 of those big circuit breakers?
« Reply #143 on: June 25, 2017, 12:10:25 PM »
Only one word
Paranoia ;)
Seriously with the amount of junk (a/c, fans, efi, stereo, and what ever else in the Kalifornia heat) that may run at the same time I'm just over doing everything. I know those breakers look huge and they are but you would normally have a fuse of some sort in the  systems. I just replaced a fuse with these breakers because I like the idea of being able to reset instead of a fuse and when I want to pull a fuse to shut a side down I just push a button. They're pretty cool if you have the room for them.
« Reply #144 on: June 25, 2017, 10:57:32 PM »
Understandable. I actually use those on several pieces of equipment at work, and they work great. I like the idea of being able to power up only what you want.
« Reply #145 on: July 01, 2017, 10:35:30 AM »
Hey guys, with regards to the EFI vs carb thread and tuning, is there value in having a constant readout via an A/F ratio gauge in the car?
I just ordered gauges and saw that it's available.
http://www.autometer.com/2-1-16-wideband-a-f-street-phantom.html
« Reply #146 on: July 01, 2017, 11:15:17 AM »
I have found it very hard to keep up with in use in a drag car, the numbers race so quickly it's hard to get use out of except maybe for some initial diagnosis.
If it will log, then it could help, but likely your EFI will already do that.
« Reply #147 on: July 01, 2017, 11:31:12 AM »
This is a street car.
I was thinking that you would get used to a range of operation, then if it broke out of that range you would have a heads up to a problem (like a sensor going bad).
« Reply #148 on: July 01, 2017, 12:14:10 PM »
For a street car I think they would be helpful, especially in a steady state situation like going down the highway, or idling in traffic.  On the track, datalogging is definitely the best way to go.
« Reply #149 on: July 03, 2017, 05:00:02 PM »
Had a great day in the garage today.
You know all those little details that you say "I'll get to that later"? The non glory stuff.
Well since everything is closed and I'm waiting for stuff, today was the day. Getting the ground path in and sound, wiring and checking brakes, clamping all the loose wire down, drilling tapping, installing the cover for the brake system and all those niggly little details that pile up.
Feels like a big leap forward. :) Stoked.
