Author Topic: 67 Mustang 390  (Read 25567 times)
Posi67
67 Mustang 390
« on: June 20, 2016, 01:29:46 PM »
Performance Summary:
      1/4 mile ET:  10.13             1/4 mile MPH: 132.58
      1/8 mile ET:   6.42              1/8 mile MPH: 106.38
      60 foot time: 1.41
      Track: Mission BC
      Weather Conditions: Cloudy.. good air
Vehicle Use: Drag Race only
Vehicle Specifications:
Model Year: 1967
Model: Mustang
Style: Fastback
Engine Details: 390 + .040,  14-1 Compression, Small Solid Roller, Mild port Edelbrock heads, Blue Thunder 2x4, 600 Vac carbs, Hooker 2 1/8"
Transmission: Jerico 4 speed
Clutch details: McLeod Softlok
Driveshaft: M/W 4" Aluminum
U-joints: 1350
Rear end type: M/W Aluminum
Differential type: Spool
Gear Ratio: 4.57
Axles: M/W 35 Spline
Front tires: Goodyear 4.5x26x15
Front wheels: Weld Alumistar 2.0
Rear tires: Goodyear 29x11x15
Rear wheels: Weld Alumistar 2.0
Front suspension information: Roller perches, custom strut rods, Strange D/A shocks
Rear suspension information: Caltrac bars and springs, QA-1 D/A shocks
Ready-to-race vehicle weight, including driver: 3200
https://youtu.be/g8AGKQGUysQ
« Last Edit: December 30, 2017, 09:49:15 PM by Posi67 »
afret
Re: 67 Mustang 390
« Reply #1 on: June 20, 2016, 02:36:11 PM »
 Super quick 390.  Sure wish the clone could run those numbers.  Thor is doing a great job gradually getting it going though.
Did Thor port your Edelbrocks?  He sure knows what he's doing.  What was the DA at the time of that run?  The air pretty much sucks at Spokane and the track prep too.  LOL
Keep up the great job with your car.
Re: 67 Mustang 390
« Reply #2 on: June 20, 2016, 03:23:47 PM »
Mission is pretty close to sea level, so I'll bet the DA was pretty low.  Wish we could run Drag Week at that track...
Posi67
Re: 67 Mustang 390
« Reply #3 on: June 20, 2016, 04:55:50 PM »
That run was yesterday and the conditions today are very similar so I checked an online site and the D/A shows 830 feet. Actual track elevation is about 25' above sea level. I don't have a weather station however when I asked a friend yesterday they said the D/A was 600'. It can get below 0 here early and late in the season and early morning but also above 2000' on a hot muggy day.
Yes, Thor is doing a great job on Afret's Stocker and he did do the Stage XR7 porting on the 390 heads. We call him "The Smart Viking" because he really does have this stuff figured out.  I suck with numbers and hate thinking. You guys should bring the car up for the National Open here and let it rip.
afret
Re: 67 Mustang 390
« Reply #4 on: June 21, 2016, 06:58:01 PM »
Yeah, maybe Thor might be able to get the car up there but he has so many things going on at the same time.  I know he's dying to get his Cougar done and out to the track.  He's too nice a guy and ends up helping everyone. LOL
Boy, a negative DA would be something.  I guess a jet change would be needed.   :)  I heard Ritchie Pauley went up there some time ago and did such a big wheelie he cracked his block where the oil pump bolts on when he landed.  It was supposed to have been a sleeved 427 block.   :'(
Russ67Scode
Re: 67 Mustang 390
« Reply #5 on: July 14, 2016, 08:32:09 PM »
How did you get an 11 inch tire under the 67? Did you move the leaf springs ? I am doing a car exactly like yours
Posi67
Re: 67 Mustang 390
« Reply #6 on: July 14, 2016, 11:04:53 PM »
Nothing is move but tire brand is the important factor. My 29x11x15 Goodyears are on a 11" rim with a 6" backspace and they just barely touch the springs and inner wheelhousing in a couple spots. My M/T's are 28x11.5x15 on 10" rims with a 5" backspace. They don't touch anywhere but also don't tuck under the car as well. My wheelwells are opened a little and the lip is rolled. I'd think a 28x10x15 tire on a 10" rim with a 5" backspacing would be a safe fit although nothing is certain. Borrowing someone's setup for a test fit would be an ideal situation.
427Fastback
Re: 67 Mustang 390
« Reply #7 on: July 14, 2016, 11:11:50 PM »
Well done Dale.....
1936 Diamond T 212BD
1990 Grizzly pick-up
fallguy72
Re: 67 Mustang 390
« Reply #8 on: July 15, 2016, 09:04:03 AM »
That's just awesome!
Re: 67 Mustang 390
« Reply #9 on: July 20, 2016, 03:09:21 PM »
i have been running mild 390s for almost 40 years thats the quickest 390 i ever heard of. man,i would like to have a 390 that runs that well. im jealous!
Posi67
Re: 67 Mustang 390
« Reply #10 on: July 20, 2016, 09:38:58 PM »
Thanks.. It's not really anything special but more like I lucked into a good combination with the parts I had. I don't play with the tune up as long as things work which seems to be happening. Don't think there's any more MPH to be had although I'm a bit surprised it's as high as it is. The ET could and should be better if I can ever figure out how to leave harder without spinning the tires but overall, I'm pretty happy with the deal.
Re: 67 Mustang 390
« Reply #11 on: July 21, 2016, 03:48:50 AM »
No Way Dale you got some kind of flux incubator stuffed in there. ::)
4twennyAint
Re: 67 Mustang 390
« Reply #12 on: October 06, 2016, 08:48:16 PM »
Nice car and impressive performance.  What are the ratios in the Jerico?
1969 Torino Cobra, SCJ 4.30, 4spd under restoration
1964 Fairlane, 428, 4spd, 4.10, 11.63@119 race trim
1966 Fairlane GTA, 482, C6, 3.50, 11.66@117 street trim
HR427
Re: 67 Mustang 390
« Reply #13 on: September 09, 2019, 05:49:19 AM »
How about loosening up the clutch to stop the tire spin
falcongeorge
Re: 67 Mustang 390
« Reply #14 on: September 09, 2019, 10:25:15 AM »
I'd heard a couple times from a couple different sources, that it is actually 14' above sea level. Its right down against the Fraser river, and the river valley itself is practically flat all the way to the ocean. Its still tidal to past the Mission bridge, which is upstream of the track, if that's any indication. I saw -800' corrected once on a jacket morning in late March.
