Author Topic: 67 Mustang 390  (Read 25545 times)
351crules
Re: 67 Mustang 390
« Reply #15 on: September 12, 2019, 01:45:07 PM »
old post but any improvements since 2016...
Posi67
Re: 67 Mustang 390
« Reply #16 on: September 18, 2019, 01:21:59 AM »
How about loosening up the clutch to stop the tire spin
I can adjust the clutch but one run the car hooks and the next it doesn't with zero changes The air here is good in the morning but can go away quickly. Trust me, I've tried every adjustment and part that's supposed to be the magic cure but in the end it comes down to track prep. Big tire cars don't care as much but us small tire stick guys need a good start line.
Posi67
Re: 67 Mustang 390
« Reply #17 on: September 18, 2019, 01:33:07 AM »
Nope.. but then I haven't done anything to affect a change. I went a 10.16 the end of last year at a different track but mostly this is a 10.20 runner. The engine seems tight and slows down with the heat. I've been running an old worn out 428 this season that has gone 9.83 and it's not as sensitive to the weather conditions.
Posi67
Re: 67 Mustang 390
« Reply #18 on: September 18, 2019, 01:48:47 AM »
I'd heard a couple times from a couple different sources, that it is actually 14' above sea level. Its right down against the Fraser river, and the river valley itself is practically flat all the way to the ocean. Its still tidal to past the Mission bridge, which is upstream of the track, if that's any indication. I saw -800' corrected once on a jacket morning in late March.
[/quote]
I've heard the 14' above as well but their website says its 25'. I've also seen it at -1800 feet on a cool clear fall day way after racing season has ended. Thing is that's never race conditions because when the air is that cool, the rack is too cold to prep or race on. What starts off at 8AM around 200 feet ends up 800 or more by 10AM and usually over 2000 feet by noon on a typical summer day. First hit is your chance to be a hero but after that you join the average.
Re: 67 Mustang 390
« Reply #19 on: September 18, 2019, 01:44:22 PM »
To bad you have to run that worn out 428 and run 9.80s that must be terrible :o :o :)
Posi67
Re: 67 Mustang 390
« Reply #20 on: September 18, 2019, 10:06:55 PM »
It's borderline tragic  ;D I've used this same engine before and it would do 10.0's on a regular basis. Had a look at things a couple years ago and other than a set of fresh roller lifters everything is the same. Now it burns oil at an idle and I almost can't stop it from running 9's. Oddly, the MPH is pretty much the same. Did take some timing out so maybe it's happier.
351crules
Re: 67 Mustang 390
« Reply #21 on: September 20, 2019, 07:53:19 PM »
awesome times..mind sharing the 428 combo?
Posi67
Re: 67 Mustang 390
« Reply #22 on: September 20, 2019, 10:22:28 PM »
Not a ton to share. I kinda borrowed this engine several years ago and the owner doesn't want it back. Before I got it, Jim Waldo did a freshen and it has his home made cross bolts. Stock Ford crank, Eagle rods and some unknown pistons that are .045 over. I was shocked that they are flat tops until I turned the Dove heads over and saw they were the small (352) chamber size. Both intake and exhaust ports are considerably smaller than my Dove heads but seem to work well. Cam is a custom Comp Roller of just over .700 lift. Intake is my Dove T-wedge with a pair of 600 vac carbs.
Tough old dog this one as it ran similar numbers in the owners Fairlane and keeps on ticking in spite of the abuse.
MeanGene
Re: 67 Mustang 390
« Reply #23 on: September 20, 2019, 11:15:46 PM »
Hey you old Canuckistani, are you coming to CHRR?
Posi67
Re: 67 Mustang 390
« Reply #24 on: September 21, 2019, 07:37:44 PM »
Not this year (again) Gene. Too far to haul my car and Jim's is apart getting freshened. A friend of mine who's never been is though. His name is Jamie Roth and he is taking his 64 Comet to run in Hot Rod class. It's a SBF stick car, the guy can drive and it runs 10.0's up here. Look him up and say nice things about me...
Re: 67 Mustang 390
« Reply #25 on: September 25, 2019, 11:01:28 PM »
I am going to be there, i'll keep Jamie in line...or push him in the line if needed.
By the way Google Earth shows between 24 and 27 feet for the track but it shows the river as 7 feet and sure ain't twenty feet down even at low tide.
I am not sure if the sea level is based on high or low tides? Whatever, it is sometimes really good air even in the summer. I've run in -1500 feet there , first pair out in the morning and in fog so thick I couldn't see the scoreboards and lifted early and missed the perfect chance to go 9's.
