Author Topic: 1UB Internally Balanced  (Read 5519 times)
darren121671
« on: May 15, 2016, 07:43:35 AM »
Hey guys,
              I was wondering if it's possible to internally balance a cobra jet crankshaft? I recently read a classified ad of a person selling an 427 engine with a 1UB crankshaft that he claims is internally balanced. Is this possible?
Yellow Truck
Re: 1UB Internally Balanced
« Reply #1 on: May 15, 2016, 08:21:12 AM »
Yes.
fryedaddy
« Reply #2 on: May 15, 2016, 11:57:23 AM »
i had my 428 crank int. balanced.now i can use a common 390 flywheel.it is a little costly because that mallory metal used to add weight aint cheap
« Last Edit: May 15, 2016, 12:00:02 PM by fryedaddy »
darren121671
« Reply #3 on: May 15, 2016, 05:31:32 PM »
So it is possible, just with extra expense versus a standard balance job?
Posi67
« Reply #4 on: May 15, 2016, 09:50:41 PM »
It's done all the time and actually the proper way to go. Depending on the piston/rod combo you should see about 3 slugs Mallory metal on the back counterweight and maybe elsewhere. Internal balance of that crank will have other tell tail signs but the added weight is the most obvious.
darren121671
« Reply #5 on: May 18, 2016, 08:52:44 PM »
Thanks guys. That's what I wanted to know.
Qikbbstang
« Reply #6 on: May 24, 2016, 07:59:49 AM »
Ironically my 428 cranks (that I shipped all the way to Ark Ak to be machined) is being done right now for my 427. I will be tickled green ($$$) if it only takes 3 slugs - I'm expecting more
fryedaddy
« Reply #7 on: May 24, 2016, 11:46:15 AM »
i ended up spending a grand on my crank
