FE Technical Forum
1UB Internally Balanced
Topic: 1UB Internally Balanced (Read 5525 times)
darren121671
Newbie
May 15, 2016, 07:43:35 AM »
Hey guys,
I was wondering if it's possible to internally balance a cobra jet crankshaft? I recently read a classified ad of a person selling an 427 engine with a 1UB crankshaft that he claims is internally balanced. Is this possible?
Yellow Truck
Re: 1UB Internally Balanced
Reply #1 on:
May 15, 2016, 08:21:12 AM »
Yes.
Reply #2 on:
May 15, 2016, 11:57:23 AM »
i had my 428 crank int. balanced.now i can use a common 390 flywheel.it is a little costly because that mallory metal used to add weight aint cheap
Last Edit: May 15, 2016, 12:00:02 PM by fryedaddy
1966 comet caliente 428 4 speed owned since 1983 1973 f250 ranger xlt 360 4 speed papaw bought new
darren121671
Newbie
Reply #3 on:
May 15, 2016, 05:31:32 PM »
So it is possible, just with extra expense versus a standard balance job?
Posi67
Sr. Member
Reply #4 on:
May 15, 2016, 09:50:41 PM »
It's done all the time and actually the proper way to go. Depending on the piston/rod combo you should see about 3 slugs Mallory metal on the back counterweight and maybe elsewhere. Internal balance of that crank will have other tell tail signs but the added weight is the most obvious.
darren121671
Newbie
Reply #5 on:
May 18, 2016, 08:52:44 PM »
Thanks guys. That's what I wanted to know.
Qikbbstang
Reply #6 on:
May 24, 2016, 07:59:49 AM »
Ironically my 428 cranks (that I shipped all the way to Ark Ak to be machined) is being done right now for my 427. I will be tickled green ($$$) if it only takes 3 slugs - I'm expecting more
Reply #7 on:
May 24, 2016, 11:46:15 AM »
i ended up spending a grand on my crank
FE Technical Forum
