Author Topic: Logo removal - Edelbrock heads  (Read 18818 times)
4twennyAint
« on: March 18, 2012, 08:15:18 PM »
Milling down just enough to remove the lettering, and leaving as much material as possible surrounding the two bolt holes, can the Edelbrock engraving be safely milled off the face/end of the cylinder head?
1969 Torino Cobra, SCJ 4.30, 4spd under restoration
1964 Fairlane, 428, 4spd, 4.10, 11.63@119 race trim
1966 Fairlane GTA, 482, C6, 3.50, 11.66@117 street trim
Re: Logo removal - Edelbrock heads
« Reply #1 on: March 18, 2012, 08:29:36 PM »
I've never tried that, but there is no reason it couldn't be done.  I don't think I'd hesitate to do it if I really wanted the logo gone.
AlanCasida
« Reply #2 on: March 18, 2012, 10:04:59 PM »
The last time I was at Gessford Machine Shop, they had a pair of heads they removed the logo from with no problems. When/if I ever get a pair that is what I an going to have done.
« Reply #3 on: March 18, 2012, 11:49:34 PM »
Barry R might stop in here sometime soon and add to this, but I've seen work he's done that, among other things, has had the milling operation you describe. He has no problem with doing so.
« Reply #4 on: March 19, 2012, 11:21:29 AM »
I had that done to my Edelbrock heads.
paulie
rcodecj
« Reply #5 on: March 19, 2012, 11:26:14 AM »
I wish I had had Barry do that to mine while they were at his shop.  8)
« Reply #6 on: March 19, 2012, 11:40:08 AM »
Maybe you could fill the logo in, with JB weld or something similar, and paint over it?
paulie
« Reply #7 on: March 19, 2012, 12:55:20 PM »
That's what I was thinking too. After recently hearing about how well J.B. Weld has worked in other situations
(fixing damaged fins on a valve cover) maybe clean the area with acetone, add Weld, then power sand down with a 4x5 sander. Heck, then one could even do this on the car with one of those mini sanders for corners, the ones with the triangular shaped head.
« Reply #8 on: March 19, 2012, 02:37:01 PM »
I bet it would work.  And if it didn't the worst that would happen would be the JB Weld falling out.   Maybe punch some dimples or otherwise roughen up the area to give it more purchase?
paulie
hotrodfeguy
« Reply #9 on: March 19, 2012, 10:45:40 PM »
The same is done for head codes like C8AE-H on Edelbrock heads  ;D
« Reply #10 on: March 20, 2012, 07:49:01 AM »
No problem at all.  We do it all the time.  Vertical riser insert on the Bridgeport make it easy to stand a head upright.
« Reply #11 on: March 20, 2012, 10:34:29 AM »
Barry, I've never seen a vertical riser insert for a Bridgeport.  You don't happen to have a photo of that, do you?
« Reply #12 on: March 20, 2012, 07:39:32 PM »
Don't have a pic of mine handy - but there are a couple 8" ones on ebay right now.
Not expensive or fancy - just kinda heavy and fun to install.
http://www.ebay.com/itm/8-Riser-Block-Vectrax-Bridgeport-Type-Vertical-Knee-Mills-/130629145267?pt=LH_DefaultDomain_0&hash=item1e6a1a92b3
« Reply #13 on: March 20, 2012, 07:42:46 PM »
Thanks Barry.  Yikes, imagine installing THAT thing... :D
« Reply #14 on: March 20, 2012, 08:30:12 PM »
Hey, way cool Barry! Knew they existed but never saw one before.
