Author Topic: Logo removal - Edelbrock heads  (Read 18819 times)
Clark Coe
Re: Logo removal - Edelbrock heads
« Reply #15 on: March 20, 2012, 09:44:42 PM »
On a similar note, Edelbrock logo can be removed from Streetmaster and Edelbrock water pump. Not really trying to fool anyone, just maintain more stock look and lose weight on front. This 9.5 C.R. 390 is not a sleeper….it is mostly asleep.
Used die grinder with aluminum burrs, lots of emery paper on wood stick and retextured with sand blasting.
TimeWarpF100
« Reply #16 on: March 23, 2012, 01:09:27 AM »
Milling down just enough to remove the lettering, and leaving as much material as possible surrounding the two bolt holes, can the Edelbrock engraving be safely milled off the face/end of the cylinder head?
I did mine in approx 10-15 Min each. About the same time to do the Edel water pump too.
falcon428
« Reply #17 on: April 01, 2012, 09:30:15 PM »
They are removed on my 482 with no problem.
'65 Mercury Comet w/ Pond Alum. 427, C6
'61 Ford Starliner w/ 352, C6
'68 Falcon w/ ProCharged FE, Lenco 5sp
'67 Country Sedan SW
'62 Falcon awaiting turbocoupe motor & tranny
'40 Ford Tudor Sedan all original
427Fastback
« Reply #18 on: April 08, 2012, 12:19:02 AM »
I removed the logo on my "E" heads at work on our horizontal boreing mill...Took longer to set it up than it took to do the cut..Took off .015 to remove the logo..Very simple and quick to do...
I see no reason why JB Weld/Devcon or Marine Tex couldnt be used to fill the lettering..They all should tolerate the heat.
Cory
1936 Diamond T 212BD
1990 Grizzly pick-up
4twennyAint
« Reply #19 on: April 09, 2012, 10:23:51 PM »
Thanks to everyone for the input.  A lot of nice looking engines as well.
Doug
1969 Torino Cobra, SCJ 4.30, 4spd under restoration
1964 Fairlane, 428, 4spd, 4.10, 11.63@119 race trim
1966 Fairlane GTA, 482, C6, 3.50, 11.66@117 street trim
