Author Topic: A look at the "new" Harland Sharps  (Read 10552 times)
« on: January 08, 2016, 12:13:33 PM »
Got my set of rockers in yesterday. Since we really haven't seen much of them I thought I'd give you a close up look.
They're blue because it was a set that was left over from their stock from producing for the other company (which I forget who) and they gave me a good deal on them. I'm diggin' the blue anyway because after all it is a Ford.
1.76:1
Re: A look at the "new" Harland Sharps
« Reply #1 on: January 08, 2016, 12:38:29 PM »
Standard oiling or push rod oiling. ?
« Reply #2 on: January 08, 2016, 01:26:14 PM »
Push rod.
« Reply #3 on: January 08, 2016, 03:02:36 PM »
Dang..
« Reply #4 on: January 08, 2016, 04:07:32 PM »
Those look real nice, Marc. The only thing I would have like to have seen would be a "hat" or clamping deal for under the shaft bolts, similar to what is on the hold-down bolts. Still, it looks like a very nice middle of the road set-up, in between the T&D Race and something like the Oregon system I have. Good score getting a deal on them!
« Reply #5 on: January 08, 2016, 04:16:16 PM »
Edit: thought you were talking about the hold down bolts to the head, not to the stand.
I figure since they are in a saddle and its a solid shaft, they figured they didn't need 'em.
« Last Edit: January 08, 2016, 04:26:05 PM by turbohunter »
« Reply #6 on: January 08, 2016, 04:33:52 PM »
Gotta thank my brother for that. Turns out he and Randy have known each other for quite awhile.
I did talk to Steve on the phone about getting an extra set of pedestals to play with modifying them for more hold down power.
But I'm gonna run these as is for a while and see what happens first.
« Last Edit: January 11, 2016, 01:09:14 PM by turbohunter »
« Reply #7 on: January 08, 2016, 05:23:18 PM »
Any chance you are going to pull it apart so you and well
the rest of us can see inside.
Look pretty nice.
« Reply #8 on: January 08, 2016, 05:32:11 PM »
Yeah, it'll be coming apart.
I'll try to remember to shoot some pics.
« Reply #9 on: January 08, 2016, 08:58:32 PM »
Sweet setup Marc. I like the blue also. Because Ford, and my favorite color is blue.  ;)
I don't think there will be much to see once it's apart being a solid shaft and all, but wouldn't mind seeing your pics.
Here is a photo of the rocker by itself I took at PRI. The typical bronze bushing. It has a full groove in the center of the bushing and an oil hole in the rear of that groove leading to the adjuster. I didn't see a second oil hole in the front going to the roller tip, so I figure they must have an oil groove cut into the rocker body and oil passes under the bushing to the roller tip.
« Reply #10 on: January 08, 2016, 09:32:22 PM »
Check one of my pictures. There is a hole leading to the roller at the tip.
« Reply #11 on: January 08, 2016, 09:44:12 PM »
Sorry for any confusion Marc. I prolly coulda worded it better. I did see the external oil hole.( looking at outside of rocker body) in person and your photo/ I did not see a second hole in the bronze bushing that leads to the roller tip, only the rear facing one going to the adjuster. That is why I assume there is a groove under the bushing that leads to that oil hole at the roller tip.
« Reply #12 on: January 08, 2016, 09:48:32 PM »
Ah ok.
Be fun to take one apart.
« Reply #13 on: January 08, 2016, 09:58:37 PM »
So the oil comes up the push rod and then the adjuster is banjoed and then the feed to the rocker bearing
then out to the tip?
« Reply #14 on: January 08, 2016, 10:10:21 PM »
That's what I'm figuring Howie.
I'll email Randy and get the real skinny.
« Last Edit: January 11, 2016, 01:09:52 PM by turbohunter »
