Author Topic: A look at the "new" Harland Sharps  (Read 10552 times)
Re: A look at the "new" Harland Sharps
« Reply #15 on: January 08, 2016, 10:12:49 PM »
So the oil comes up the push rod and then the adjuster is banjoed and then the feed to the rocker bearing
then out to the tip?
Yes, like a T&D race rocker.
« Reply #16 on: January 11, 2016, 01:08:36 PM »
Here's the email Randy just sent me back.
Marc,
The oil comes up thru the pushrod and into the rocker via a small oil hole
drilled in the adjuster.  We then have a groove in the rocker the oil can
travel around allowing some to flow out to the roller tip and the rest is
used to lubricate the shaft.  Most important is the pushrod length so that
the oil hole in the adjuster lines up with the oil hole in the rocker to
allow for the oil to flow.  Hope this helps.  Let me know if you have any
other questions.  Thanks.
Randy Becker Jr.
So I'll take them apart to see all that as soon as I get a chance.
« Last Edit: January 11, 2016, 01:13:50 PM by turbohunter »
Qikbbstang
« Reply #17 on: January 11, 2016, 03:06:03 PM »
I just grabbed an "old" gold Harland Sharp and was surprised to find no oiling "jets" at all to the roller end. There is one jet to the pushrod side of the rocker.
    I looked at a Dove roller and it had oiling to both the push-rod and roller side....
 Are Harland Sharp "old gold" rockers only one-side oiling, on the pushrod side?
